Issues with probe at position 1
  • I configured 2 probes on my machine (K0 and K1), and I never see K1 value change with G31 K1 (and I see the corresponding LED change value on the board when I activate the switch by hand), but when I move it to K0, then G31 K0 does reflect the status of the probe.
    here is a sequence of event (time flow bottom up):
    <---- release ystop
    18:07:24G31 K0
    Current reading 1000, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
    <---- activate ystop by hand
    18:07:16G31 K0
    Current reading 0, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
    18:07:04M558 K1
    Z Probe 1: type 0, invert no, dive height 5.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
    18:07:00M558 K0
    Z Probe 0: type 5, input pin !ystop, output pin nil, invert no, dive height 5.0mm, probe speed 10000mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
    18:06:55M558 K0 P5 C"!ystop" F10000
    18:06:39M558 K1 P0 C"nil"
    <---- release ystop
    18:06:02G31 K1
    18:05:49G31 K1
    18:05:36M558 K1
    Z Probe 1: type 5, input pin !ystop, output pin nil, invert no, dive height 5.0mm, probe speed 10000mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
    18:05:30M558 K0
    Z Probe 0: type 5, input pin !e1stop, output pin nil, invert no, dive height 3.0mm, probe speed 400mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 5, max diff 0.03
    18:05:14M558 K1 P5 C"!ystop" F10000
    18:04:59M574 S1 Y0 C"nil"
    some version strings:
    Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
    Firmware Electronics:	Duet WiFi 1.02 or later + DueX5
    Firmware Version:	3.0 (2020-01-03b3)
    WiFi Server Version:	1.23
    Web Interface Version:	1.22.6
  • I don't think multiple probes is currently fully implemented.
