    Fan output
    • Scrabartundefined
      Scrabart
      I am trying to use a fan [fan1] output to drive a relay input.
      However, even if I use a M106 P1 S0 command, the voltage drops only to 0.4 volts, which is not low enough to switch the relay off. Any thoughts on how to pull the fan output closer to 0V?
      • SIamundefined
        SIam
        you can add a transistor to solve this look at this example
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
