    Unable to connect to Duet Web Control http://127.0.0.1
    Duet Web Control
    • luckyflyerundefined
      luckyflyer
      I'm new to Duet so apologies in advance if I'm overlooking something simple.
      I've installed DuetPi with gui with wifi enabled on a Duet 3. I can log in with VNC viewer, I can also ssh in with putty. I've done the sudo apt-get update and sudo apt-get upgrade. When I goto http://127.0.0.1 which is Duet Web Control I get "This site can’t be reached 127.0.0.1 refused to connect."
      I have also entered these commands ,sudo systemctl start duetcontrolserver, sudo systemctl enable duetcontrolserver and sudo systemctl start duetwebserver with no errors but still cannot log into Duet Web Control. When I go in via VNC I get what I think is Duet web control ( the program doesn't say). It has machine control, current job etc. I'm using chrome and octoprint works on my other machine. Also I don't have the Duet 3 actually in a printer, it's on my workbench with a pi 3B+ and a panel due 5i connected and that's all. Can you help me figure this out,thanks.
      • SIamundefined
        SIam
        ähm you must use the external ip from your raspi and not the localhost ip 127.0.0.1
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          luckyflyer
          Wow it was simple, works perfectly, thank you.
