    Connecting to PT100 board via the jumper pins?
    • martinkundefined
      martink
      I'm assembling my e3d toolchanger and opted for PT100 sensors. Given that almost everything is connected to the Duet2 using Molex KK-style connectors, I was wondering if I could (ab)use the jumper pins on the PT100 board instead of the screw terminals for a 4-wire connection using the Molex connector.
      So on the board side, I'd have a 4 pin KK connector, and on the tool head, I'd crimp a wire pair to each pin of a Microfit connector to mate with the one on the E3D sensor.
        Yes you can do that.
        • martinkundefined
          martink
          Thanks 🙂
