Bed leveling dual Z motor programming
  • I have the same bed size they describe in the "Bed levelling using multiple independent Z motors" article,
    ( https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors)
    ... The code looks like the following for config.g
    M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
    M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
    ... Here is the bed.g code
    G28 ; home
    M401 ; deploy Z probe (omit if using bltouch)
    G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
    G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
    M402 ; retract probe (omit if using bltouch)
    so I'm thinking I'll just copy/paste into my config.g and bed.g files. My question is, where should they go in the file? Should I put them at the top of the "Drive" section?
    My current config.g looks like this (With questioned areas noted);
    M569 P0 S0 ; Physical drive 0 goes Backwards
    M569 P1 S0 ; Physical drive 1 goes Backwards
    M569 P2 S1 ; Physical drive 2 goes forwards
    M569 P3 S0 ; Physical drive 3 goes forwards
    SHOULD I PUT THE CODE HERE?!
    DO I NEED TO CALIBRATE EACH STEPPER MOTOR INDEPENDENTLY?
    M92 X99.9 Y100.1 Z399.6183 E100 ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z4000.00 E1200.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
    M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X210 Y210 Z200 S0 ; Set axis maxima
    M574 X1 Y1 S1 ; Set active high endstops
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P500 X34.82 Y-8 Z0.073 ; Set Z probe trigger value, offset and trigger height
    M557 X0:200 Y15:200 S50 ; Define mesh grid
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    Set idle timeout Same question for the bed.g file.. Thank you! I'm rather hopeful this will solve the extrusion issue and get to printing.
  • @hbrownell said in Bed leveling dual Z motor programming:
    G28 ; home
    if you dont use a bl touch remove the M402
