    Duet3 upgrade - java error
    Firmware installation
    46
    • jens55
      jens55 last edited by
      I upgraded to Duet3 and now, as soon as the web interface loads, I get a java error and the web interface disconnects.
      Any suggestions on how to get past the error ?
      I am still running the old version of the web panel.
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @jens55 last edited by
        @jens55
        Update to the new one
        • jens55
          Was hoping to deal with one upgrade at a time 😞
          Since the web interface is hooped, I am guessing I pull the memory card and put a fie directly onto the card. Is there a writeup someplace that coverswhich files to put where on the card ?
          • jens55
            There is DuetWebControl-SD-2.04.zip in the upgrade release - do I just unzip it and load it onto the memory card ?
            • jens55
              Took the files in DuetWebControl-SD-2.04.zip and over-wrote them onto the /www subdirectory but the web panel still comes up as version 1.xx together with the java error.
              • SIam
                SIam last edited by
                i'm not 100% shure make a backup from your www directory remove the old data and upload the new data to it.
                  dc42 administrators @jens55 last edited by
                  @jens55 said in Duet3 upgrade - java error:
                  Check that you really do have the files in /www. One of the files in /www should be index.html, which is the root file for DuetWebControl 2. The firmware will only serve the old file (reprap.htm) instead only of it doesn't find that file.
                  jens55 1 Reply Last reply Reply Quote 0
                  • jens55
                    jens55 @dc42 last edited by
                    @dc42 Ahhh, I had a shortcut in my browser set to reprap.htm ..... went back to just the ip and got the new web interface. Unfortunately this brought up a second issue (doesn't it always) in that I can't seem to go back to the old user interface which I prefer.
                    I put the reprap.htm file back on the memory card, it sees it and displays it but without any formatting like boxes and things, it just prints it as individual lines. What else did I manage to screw up ?
                      dc42 administrators @jens55 last edited by dc42
                      It sounds like you deleted some of the other DWC 1.22.6 files from /www. Just reinstall them. You can have both DWC2 and DWC 1.22.6 files in the /www folder, they don't interfere with each other.
                      Is there anything in particular you do that provokes the Javascript error when you use DWC 1.22.6 with RRF3? I've just tried it and so far it works for me.
                      • jens55
                        The javascript error went away after I upgraded to the new web panel and after I didn't go directly to the reprap.htm page.
                        I thought I had all the old files re-installed but since you mention it, I did not re-install the old files in the folders that were upgraded, just in the /www directory itself. It now makes sense why I am getting what I am getting
                        Thank you !
                          What I meant was, when you were using the old Duet Web Control (version 1.22.6?) with RRF3, did the javascript error occur immediately, or only when you did something in particular? DWC 1.22.6 is working for me with RRF3.
                          • jens55
                            The javascript error popped up immediately upon completion of loading the page.
                            Furthermore, now that I have all the files re-installed, when I go to the old web interface I get the javascript error again (but at least the page formatting is correct now)
                            Version: 1.22.6
                            Message: Type Error: lastStatusResponse.temps.current[heater] is undefined
                            URL: http://192.168.1.114/js/dwc.js
                            Line: 4468:8
                            Error object: {}
                              Version: 1.22.6
                              Line: 4468:8
                              Error object: {}
                              Thanks. This may be caused by a bug in RRF 3.0 that I have fixed since that release. Also, have you numbered the heaters consecutively? I'm not sure whether DWC 1.22.6 can handle gaps in the numbering.
                              • jens55
                                jens55 last edited by jens55
                                No, the heaters are not numbered sequentially ... my second extruder, heater and sensor is on a duex5 board.
                                I should add that the setup worked fine under Duet2
                                  That may be the problem then. In RRF2, all heaters existed even if you didn't use them. In RRF3, only heaters you create using M950 exist. If that's the problem, then a solution would be to renumber the heaters in your M950 and M563 commands so that there are no gaps in the numbering. So you would call the first heater on the DueX board heater 2 instead of heater 3.
                                  • jens55
                                    @dc42 RRF3 is not yet configured at all so I don't expect anything to work BUT .... it makes no sense for the web control panel to break if there is an issue with the printer configuration. In other words, the new web panel handles things as it should but the old one has a programming error of some kind.
                                    If the old web panel is still deemed 'supported' then that fix should be back-ported.
                                    Of course it doesn't help that most users probably use the web panel to set up the printer configuration 😞
                                    Maybe this conversation will land on the right desk and a fix will happen .....
                                      The old web interface isn't actively supported with RRF3, but I was interested to find out why it didn't work for you.
                                      • jens55
                                        It is unfortunate that the old web interface is no longer supported.
                                        Hopefully it will work once Duet3 is properly configured.
                                          We don't have enough resources to justify supporting 2 different web interfaces. But everything is open source, so anyone who wants to is free to do their own web interface, or adapt old versions to new RRF releases.
                                          • jens55
                                            Of course .... and I understand .... but it is still unfortunate ....
                                            • jens55
                                              jens55 @jens55 last edited by jens55
                                              I should add that I appreciate the support that you give even though your resources are very limited !
                                              Also, thank you to all the other people that help in supporting the whole Duet system! I am sure that it wouldn't be half as successful without the effort of a lot of people!
                                              Thank you !
