    BLtouch convert settings from 2.X to 3.X, cant get it to work.
    • brasse
      brasse last edited by
      Hey.
      Im a bit confused about the new way to set up BLtouch on the new 3.0 firmware, can someone help me to get it right?
      Working configuration in 2.03:
      config.g
      M307 H3 A-1 C-1 D-1 ; Disable the 3th Heater
      M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves. BLtouch
      retractprobe.g
      M280 P3 S90 I1
      deployprobe.g
      M280 P3 S10 I1
      This is config.g (generated from the online config-tool), based from my old config
      M950 S0 C"e3heat" ; create servo pin 0 for BLTouch (also tried e1heat as the generation tool suggested)
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      I cant get the probe to deploy/retract (M401,M402) with this config on 3.0, what am i doing wrong?
      Best Regards
      • chrishamm
        chrishamm administrators last edited by
        Your deployprobe.g/retractprobe.g is wrong. The configtool generates this and it should work:
        config.g:
        M950 S0 C"duex.e3heat"                         ; create servo pin 0 for BLTouch
        M558 P9 C"zprobe.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
        deployprobe.g
        M280 P0 S10 ; deploy BLTouch
        retractprobe.g
        M280 P0 S90 ; retract BLTouch
        • brasse
          It made no difference at all, M401/M402 still does nothing 😞
          • pipersw
            pipersw last edited by pipersw
            can you post your config.g, deployprobe.g and retractprobe.g ?
            don't use pin definition for duex, but try with the extension connector pin number :
            M950 S0 C"exp.8"                         ; create servo pin 8  for BLTouch
            brasse 1 Reply Last reply Reply Quote 0
            • brasse
              brasse @pipersw last edited by
              @pipersw I have tried the configuration i posted in my first post, and i have also tried the config that "chrishamm" posted above.
              But i can repeat:
              I have tried this:
              config.g:
              deployprobe.g
              retractprobe.g
              As well as this:
              retractprobe.g
              M280 P3 S90 I1
              deployprobe.g
              M280 P3 S10 I1
              config.g
              • pipersw
                try this :
                config.g
                M950 S0 C"exp.8"                               ; create servo 0 pin 8 for BLTouch
                M558 P9 C"zprobe.in+zprobe.mod" F150 H2.5 R0.5 T2000 A10 S0.03 B0  ; set Z probe type to bltouch and the dive height + speeds
                G31 P25 X0 Y80 Z1.25                           ; Set Z probe trigger value, offset and trigger height
                deployprobe.g
                M280 P0 S10  ; set 10deg servo position on GPIO port 0
                retractprobe.g
                M280 P0 S90  ; set 90deg servo position on GPIO port 0
                don't use I1 with M280, and use the same port with M280 as define with M950
                brasse 1 Reply Last reply Reply Quote 2
                • brasse
                  @pipersw That did the trick 🙂 "e3heat" instead of "exp.8" was the main problem. Thanks!
