G0/G1 insufficient axis homed
  • After i run a job and it finishes it gives me an error
    Go/G1 insufficient axis homed
    it was homed before the job.. it should still know its position
    what will cause it to loose its position and require to be rehomed
    if it did not reset
    duet 2 wifi RRF3 non beta
  • What are the last few gcode commands in the job?
  • G1 X147.310 Y149.379 E0.5177
    G92 E0.0000
    G1 E-1.0000 F2400
    ; layer end
    M106 S0 ; turn off cooling fan
    M104 S0 ; turn off extruder
    M140 S0 ; turn off bed
    M84 ; disable motors
    I assume the M84 is causing my problem
  • @Adamfilip said in G0/G1 insufficient axis homed:
    correct, that will leave the printer in a unhomed state (as the motors could move when not powered, and I believe you'll lose any microstep positioning and start from the nearest full step possition when powered back up)
