DWC 2.05 Temperature Controls
Duet Web Control
  • undefined
    tekkydave
    I've just upgraded to DWC 2.05 (from 2.04) and the hotend/bed manual temperature controls seem to have a strange behaviour:
    If I select a temperature from the dropdown it displays it but the heater stays at the current temperature. When clicking away it reverts to zero. I can manually type in a value and hit return but it is selecting another random value from the dropdown.
    This is the same for RRF 3.0 or 3.01beta1.
    No problem experienced using 2.04 and if I revert to 2.04 the problem disappears.
    Also - M104 & M140 gcodes seem to work ok with the set temperatures showing up in DWC.
    My config.g (nothing has changed between DWC 2.04 & 2.05)
    config.g
    ~ tekkydave ~
    D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
    FreeCAD, PrusaSlicer
    • undefined
      chrishamm administrators
      I'm about to release DWC 2.0.6 which will fix this.
      Duet software engineer
      • undefined
        tekkydave
        Ok. I'll give it a test as soon after release as possible 🙂
        EDIT: I guess this is linked to auto-completion somehow. Disabling it also disables the temperature dropdowns.
        ~ tekkydave ~
        • undefined
          This should be fixed in v2.0.6.
          undefined 1 Reply Last reply 16 Jan 2020, 09:16 Reply Quote 0
          • undefined
            tekkydave @chrishamm
            @chrishamm Yes, confirmed fixed. Many Thanks 🙂
            ~ tekkydave ~
            1 out of 5
