    Duet3 and Hotend fans on reboot
    • kraegar
      kraegar last edited by
      So, I power my pi off of my duet3 currently, and it's troubling that when I reboot the pi there's a long delay while it boots before the hotend fan turns on. I know I can set the pi to be externally powered, but still, there will be that chance of a reboot while my hotend is at temp. What is the best option for dealing with this so we don't get heat creep during reboots?
      • gtj0
        gtj0 last edited by
        I think there'd need to be some sort of "config-startup.g" on the Duet3's sd card with basic settings like the heaters, fans, thermistors, etc. The firmware would have to look for that file, execute it, then wait for a new config from the SBC. @dc42 ?
        • Danal
          Danal last edited by Danal
          From power on to fan running is 19.5 seconds on my machine. Duet 3 6HC, two 3HC expansion, Pi 4.
          This strikes me as a non-problem.
          • chrishamm
            chrishamm administrators last edited by
            It's also worth mentioning that the Duet 3 will keep its config.g parameters while the Pi reboots. When that is the case, the Duet 3 remains functional quasi-standalone mode with the previously processed configuration. If waiting 20s after a hard power failure is an absolute no-go, perhaps it is a better idea to use always-on fans or even a small UPS.
