    Can't read Current Pressure Advance Using Web Console in DWC
    Firmware developers
    • ctilley79
      ctilley79 last edited by
      I'm running RRF 3.0 final and DWC 2.04 on my Duet 2 WiFi. I'm trying to return the current pressure advance value by entering M572 or M572 D0 in the web console and the functionality seems to be broken. I get the green banner that the command was accepted, however it's not returning anything, aka no blue banner with the values. My other Duet Wifi running RRF version 2.05 works just fine.
      One thing to note. I'm using firmware retraction and I'm setting both retraction values and pressure advance amount in the config file for my filament.
      • deckingman
        deckingman @ctilley79 last edited by
        @ctilley79 Does the value appear in console window? Do you get any message such as "Response too long - see console?
        ctilley79 2 Replies Last reply Reply Quote 0
        • ctilley79
          It does not appear in the console page either. Only the green highlighted line that the command was accepted.
          • ctilley79
            ctilley79 @deckingman last edited by
            @deckingman Actually. It now seems to intermittently work. I'd say 1 in 5 times after sending the command.
            • ctilley79
              • chrishamm
                chrishamm administrators last edited by
                Close the second browser instance running DWC/DWC2 and it will work again. RRF caches the G-code reply only once per IP address.
                ctilley79 1 Reply Last reply Reply Quote 1
                • ctilley79
                  ctilley79 @chrishamm last edited by
                  @chrishamm Son of a bitch that did it. Thanks man.
