    RRF3.0 & z-probe
    Firmware installation
    • ludisnetundefined
      ludisnet
      After switching to RRF3.0, I can no longer do automatic G32 calibration:
      1/ the z-probe measurement is no longer on the web interface ( => it can be displayed with the parameter "return to DWC1")
      2/ when I launch G32 , it launches a "manual" z-probe, and not automatic !
      My config in config.g :
      ; ***** Z probe and compensation definition *****
      M558 P1 F100 T3000 X0 Y0 Z0 H4 ; Z probe is a Smart Effector
      G31 P500 X0 Y0 Z1.80 ; Set the zprobe height and threshold for Smart Effector
      M557 R85 S20 ; define mesh grid
      My config in bed.g :
      M561 ; clear any bed transform, otherwise homing may be at the wrong height
      G28
      G30 P0 X0.00 Y80.00 Z-99999 H0
      G30 P15 X0 Y0 Z-99999 S6
      G1 X0 Y0 Z150 F6000 ; get the head out of the way of the bed
      M500 ;
      G29
      Anything changed about the G32 calibration?
      Thanks.
      Ludis
        dc42 administrators @ludisnet
        @ludisnet said in RRF3.0 & z-probe:
        Add the pin name of the Z probe to the M558 command. Also you should use P8 for Smart Effector, not P1, and a higher probing speed. This is what I use on my delta, with Duet WiFi with RRF 3.01beta1:
        M558 P8 C"zprobe.in+zprobe.mod" H4 F1000 T12000 R0.2 S0.02 A5
        G31 X0 Y0 Z-0.10 P100
        • ludisnetundefined
          ludisnet
          @dc42 : Thanks, G32 work well now.
          Now, I wanted to make a G29 (I discover...), and after launching G29, in the middle of the bed, it displays an error:
          G29
          Error: Z probe already triggered before probing move started
          Do you know why?
          my parameter in config.g :
          In the GUI, the M557 setting parameters (...define zone) do not take over the values from config.g ...what to do?
          Thank you.
          PS : delta, with bed radius ~100cm
          • ludisnetundefined
            ludisnet
            so, i reduce speed (z-probe), and work without error ....
            with :
            M558 P8 C"zprobe.in+zprobe.mod" H4 F500 T8000 ; R0.2 S0.02 A5
            Ludis
              with :
              Ludis
              You could increase the R parameter, to allow the effector more time to settle before probing starts.
