    Laser Questions: How to focus len with it firing low power?
    Laser Cutters
    738
    • otaku521undefined
      otaku521
      Finally I got my laser fired up (2 pin PWM+ 2 pin 12v power) using heater 6 on the expansion board (via 2.05 firmware)
      Doing a test print on inkscape via 306 engineering raster to gcode plugin... just printing "ABCDEF"
      I noticed that:
      1. firing is very spotty across the row- it doesn't look like letters - could this be focus?
        a) If so, what is the gcode to have the laser turn on at 1% (or low power) so I can make focus adjustment?? tried M3 S10 and it didn't fire, but while doing G1 X100 S100 it does move and fire...
        tried it with sticky M457's S1 sticky ... still no good
      2. if it is not focus issue - can anyone please advise me?
      3. I have tried lightburn - cannot find save gcode using smoothieware or marlin as profile?
      Tony
      • A Former User?
        A Former User
        @otaku521 said in Laser Questions: How to focus len with it firing low power?:
        doubt it, focus would be blurred edges and consistently weak lines. spotty is either smoke or isses with g-code generation or interpetation i would think.
        I think that is a safety feature that laser is only enabled when moving, i don't recall the config off the top of my head but if its not configurabel, you can try freeing up the laser pin and using M42 instead.
        • otaku521undefined
          otaku521
          hrmmm.... since I am heater 6... so this means:
          M42 P6 S10
          would fire the laser on low power (hopefully..)
          I did read somewhere on the forum that you can not fire without moving...
          they said made a macro for it.. but Don't know how....
          Would you or anyone kindly share how?
          thanks
          Tony
          • otaku521undefined
            otaku521
            M42 P6 S10
            yes it works! thanks!
            but I need to have it set M42 P6 S255 in order to work.... any other value the laser is off...
            how come?
              droftarts administrators
              @otaku521 How is your gcode being generated? Generally, it's advised to use G1 with and S parameter to set laser power for each move, rather than M3 and M5. I think Lightburn can output the correct G1 S# gcode. If you can post a snippet it might help.
              There are these changes in RRF 2.05 that are worth checking (see https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md) :
              Changed behaviour:
              • In laser mode (M453), M3 never turns on the laser immediately. Instead it sets the default laser power for following G1/G2/G3 commands. Likewise, M5 does not immediately turn off the laser, it sets the default laser power for following G1/G2/G3 commands. If a subsequent G1 command has a S parameter, the value of that parameter becomes the default laser power for that command and subsequent G1/G2/G3 commands.
              Bug fixes:
              • In laser mode, M3 and M5 commands used in a job gave unpredictable results
              And from RRF 2.04, Feature improvements/changed behaviour:
              • In Laser mode, if sticky laser power mode is selected, the power set by the S parameter in a G1 command is remembered across G0 moves to the next G1 move
              See this thread for extra detail:
              https://forum.duet3d.com/topic/8339/laser-turns-off-after-following-code-is-sent-after-m3
              • A Former User?
                A Former User @otaku521
                could be several reasons for it. simplest is the laser doesn't actually do power regulation. or its the wrong frequency or the pin used doesn't support pwm, laser doesn't work well with the given voltage level or gremlins?
                which laser, which driver, how is it wired etc?
                • otaku521undefined
                  otaku521
                  Hi everyone!
                  Here is the hook up
                  Here is the config.g:
                  M667 S1 ; Select CoreXY mode
                  G21 ; milimeter Mode
                  M550 PLaserMk1 ; Set machine name
                  M551 Pabcd1234 ; Set password
                  M587 S"XXXXXXXX" P"xxxxxxxx" ; Configure access point. You can delete this line once connected
                  M552 S1 ; Enable network
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M569 P0 S0 ; Drive 0 goes BACKWARDS (X)
                  M569 P1 S0 ; Drive 1 goes BACKWARDS (Y)
                  M584 X0 Y1 ; Drive 0-X 1-Y
                  M350 X16 Y16 I1 ; Configure microstepping with interpolation(I=1) (x16 from 16)
                  M92 X80 Y80 ; microstep 16 Interpol 256
                  M201 X1000 Y1000 ; Max Accerlation (mm/min)
                  M203 X24000 Y24000 ; Maximum speeds (mm/min)
                  M566 X1200 Y1200 ; jerk values
                  M906 X900 Y900 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S50 ; Set idle timeout
                  M208 X0 Y0 S1 ; Set axis min
                  M208 X220 Y210 S0 ; Set axis max
                  M574 X1 S1 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
                  M574 Y1 S1 ; Set active High endstops (S1=SENSORED) (Y-MAX(2)) (S3=SENSORLESS)
                  ; LASER SETTINGS
                  M307 H6 A-1 C-1 D-1 ; Clear Heater 6
                  M452 P6 R255 F200 S0 I1 ; switch to laser mode using Heater 6 PWM to control the laser
                  G10 P0 X0 Y0 ; Set tool 0 axis offsets
                  M563 P0 H6 ; Define tool 0 uses Heater6
                  T0 ; Select first tool
                  • A Former User?
                    A Former User
                    Is heater 6 output 5v or 3.3v (not familiar with Duex hardware)? Or does the 5v ttl input also work with 3.3v?
                    EasyTargetundefined 1 Reply Last reply Reply Quote 0
                    • EasyTargetundefined
                      EasyTarget @A Former User
                      @bearer
                      Feeling curious I checked, and the expansion board indeed gives a 5V pwm line for Heaters 6 and 7.
                      @otaku521 The wiring hookup looks good. And I cant see anythng amiss in the config. But the behaviour you describe sounds very much like the laser module is not accepting the PWM properly; Does it have a 'analog/ttl' switch/jumper anywhere? Do you have access to a scope or PWM aware multimeter to verify the signal level and duty cycle on the line itself?
                      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                      PrintPy2024 to the rescue!
                      MicroPython based; with simple wiring and and no custom PCB.
                      otaku521undefined 1 Reply Last reply Reply Quote 0
                      • otaku521undefined
                        otaku521 @EasyTarget
                        @EasyTarget
                        Noted I too think maybe it ttl not accept pwm
                        I am getting ttl to pwm convertor (elekmaker ttl to pwm) to see if this will fix the problem
                        Anyone hooked this up before?
                        [link text]https://a.aliexpress.com/_s8wCcG(link url)
                        • A Former User?
                          TTL in this instance is basically PWM with variable duty cycle. So if it works with TTL it should be possible to make it work with the Duet you just need to find the right combination of
                          *inverted or not inverted signal
                          *voltage (should be sorted at 5v)
                          *frequency
                          • otaku521undefined
                            otaku521 @A Former User
                            @bearer
                            So maybe I should change F200 to any other number? Spec said 0-15000
                            So set it to 15000 and try again?
                            Or R255 to R15000?
