    Endstop configuration
    • stevenrsearles
      stevenrsearles last edited by
      I have all the motors driving in the correct direction but there not stopping when being activated. The led on the duet wifi is off when not activated then turns on when i activate a mechanical switch or the induction sensor but then the motors continue to drive. i have tried to reset to both active high and active low with no change. being new to this I now don't know what i'm doing wrong or if its possible that i wired it wrong or what i might need to add or subtract from my config.g this is for a Cartesian style machine
      ; Prusa i3 config file for dc42 Duet firmware
      ; Prologue and comms section
      M111 S0 ; Debug off
      M550 PPrusai3 ; Machine name (can be anything you like)
      M551 Preprap ; Machine password
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
      ;*** Adjust the IP address and gateway in the following 2 lines to suit your network
      M552 P0.0.0.0 ; IP address (0 = use DHCP)
      M554 P192.168.1.1 ; Gateway
      M553 P255.255.255.0 ; Netmask
      M555 P2 ; Set output to look like Marlin
      M575 P1 B57600 S1 ; Comms parameters for PanelDue
      M552 S1
      ; Movement section
      M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P4 S0 ; Drive 4 goes forwards
      M574 X1 Y1 S2 ; set endstop configuration (X and Y endstops only, at low end, active high)
      M574 Z1 S1
      M906 X800 Y800 Z800 E1000 ; Set motor currents (mA)
      M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
      M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
      M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute
      M208 X200 Y200 Z200 ; set axis maxima (adjust to suit your machine)
      M208 X0 Y0 Z-0.2 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
      M92 X80 Y80 Z2560 ; Set axis steps/mm
      M92 E420:420 ; Set extruder steps per mm
      G21 ; Work in millimetres
      ; Z probe section
      M547 E0 S0 ; npn induction sensor on e0
      ;M558 P1 X0 Y0 Z1 H3 F200 T5000 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
      ;G31 P500 X11.0 Y0.5 Z1.65 ; set threshold and offsets
      ;M558 P1 X0 Y0 Z1 H3 F200 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
      ;G31 X11.0 Y0.5 Z1.20 P500 ; Set the probe height and threshold (put your own values here)
      ; Heater and thermistor section
      ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
      M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
      M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
      M570 S120 ; Increase to allow extra heating time if needed
      ; Tool definition section
      M563 P0 D0 H1 ; Define tool 0 to use extruder drive 0 and heater 1
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      ;*** If you have a dual-nozzle build, un-comment the following 2 lines
      ;M563 P1 D1 H2 ; Define tool 1
      ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
      ; Bed probe section (not needed if you use a bed.g file)
      ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of your Z probe
      M557 P0 X60 Y0 ; Four...
      M557 P1 X60 Y165 ; ...probe points...
      M557 P2 X200 Y165 ; ...for bed...
      M557 P3 X200 Y0 ; ...levelling
      M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this to get a 5th point at the centre of the bed)
      ; Epilogue
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0 ; Axis compensation here
      T0 ; select first hot end
      • stevenrsearles
        mechanical switch from closest to the switch out
        1green
        3black
        4red
        duet from top to bottom (if wifi is in bottom right hand corner)
        1black
        2red
        3green
        • stevenrsearles
          LJ12A3-4-Z/BX NPN wired
          output to cathode, anode to E0 STP pin
          ground to ground
          power to vin
          think i got a bat43 diode but might have been a 1N4148 cant remember right now what one radio shack had in stock at the time and its heat shrinked at the time
