    Big enough Power supply?
    • DallasH
      DallasH last edited by
      Do i have a big enough Power supply? I have a Delta 200 watt power supply that was the original in my 3D systems Cube pro
      2x bondtech slim nema 17
      3x oriental .09 steppers, 2 z and 1 Xaxis (PKP244MD15A2)
      1x oriental stepper y axis (PKP246MD15B2)
      2x 50 watt mosquito heaters
      2x SSR one for 110vac chamber heat, and one for 110vsz bed heater
      Panel Due
      Duex 2
      Duet2 wifi
      7x 24vdc fans
      Is there enough to run some led lights also
        Given that the largest heaters are on AC power, the rest of the system doesn't use an excessive amount. I run similar hardware on a 200w PSU without issue. Including a long strip of LEDs.
        This should help you do some more detailed reckoning.
        https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
