    RepRapFirmware 3.01-beta2 released
    Beta Firmware
    603
      It's at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-beta2. The change summary is at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
      • garyd9undefined
        garyd9
        Seems to be working fine with a stand-alone Duet3.
        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        • Danalundefined
          Danal
          Loaded on a SBC + Duet3 6HC + 2 x 3HC. Haven't printed yet, but a few quick tests looked fine.
          • zerspaner_gerdundefined
            zerspaner_gerd
            Tried RF 3.01-beta2 with the same problems
            homeall.g -> OK (also X without errors?)
            homex.g -> error
            homey.g -> OK
            homez.g -> OK
            Only homex.g fails, he drives on it once, takes off and stops, the slower approach is missing. If you press again, the following error occurs:
            G28 X
            Error: G0 / G1: insufficient axes homed
            I've shared my macros here before
            https://forum.duet3d.com/topic/13630/reprapfirmware-3-0-is-released/119?_=1580039563223
            greetings
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
              zerspaner_gerd
              Where can I look up which number corresponds to which status?
              echo state.status outputs only one number
              Thank you for many new opportunities
                dc42 administrators @zerspaner_gerd
                @zerspaner_gerd said in RepRapFirmware 3.01-beta2 released:
                There's a bug, try the internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 instead.
                • Alex.crundefined
                  Alex.cr
                  Having trouble getting my delta to home correctly after update to 3.0. I have also tried 3.01-beta2. I have performed a successful upgrade on my cartesian machine.
                  My delta keeps adding the prehomed Z height value to the new homed height. It is almost exactly double the actual machine height. This triggers an "Error: G0/G1: target position not reachable from current position".
                  This machine has a smart effector and a duet wifi. At first i thought it might be because of the config override. After playing around with this a few times I think I get it to work and then it reverts back the next time I home it.
                  I removed M501 from the config.g file and pasted the override settings into the main config. Interestingly enough if I send an M502 the machine will work for a homing cycle.
                  Anyone seen this before?
                  homedelta.g
                  config.g
                  config-override.g
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                    From your config.g:
                    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                    Endstops on a delta are at the high end, so you need X2 not X1. Same for Y and Z.
                    • Alex.crundefined
                      Alex.cr
                      Thank you dc42. I feel so stupid now...
