    Trigger height whitout Z probe
    108
    • gorie
      gorie last edited by
      I removed my Z probe and manual probing the bed.
      How can I remove the trigger height. After probing my Z go to 5.7 mm. In the dwc I see the trigger height at 0.7mm. RRF3.0 duet2 WiFi. No probe in the config.g file.
      • SIam
        SIam last edited by
        please post your config.g
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          G31 XYZ in config.g sets the probe offsets.
          Are you using M558 probe type P0 for manual probing? or what exactly do you mean about manual probing?
          • gorie
            0:/sys/config.g
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Jan 21 2020 00:17:12 GMT+0100 (Midden-Europese standaardtijd)
            M550 P"HEVO" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P3 S0 ; physical drive 3 goes backwards
            M92 X80.00 Y80.00 Z400.00 E821.48 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X0 Y0 Z390 S1 ; set axis minima
            M208 X380 Y350 Z0 S0 ; set axis maxima
            M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
            M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
            M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:380 Y15:350 S50 ; define mesh grid
            T0 ; select first tool
            HEVO
            Send code...
            Status
            Idle
            Mode: FFF
            Tool Position
            X
            0.0
            Y
            0.0
            Z
            0.00
            Extruder Drives
            Drive 0
            0.0
            Speeds
            Requested Speed
            0 mm/s
            Top Speed
            0 mm/s
            Sensors
            Vin
            23.7 V
            MCU Temperature
            23.2 C
            Tools
            Extra
            Control All
            Tool Heater Current Active Standby
            Tool 0
            T0 - Volcano PLA Heater 1
            active 18.3 C
            0
            0
            Bed Heater 0
            off 18.3 C
            0
            0
            Temperature Chart
            System Directory
            • SIam
              SIam last edited by SIam
              G31 is missing so you dont set a offset
              • gorie
                Is that necessary if you don't use a probe?
                • SIam
                  SIam last edited by
                  good question ... try it, it will cost nothing 😉
                    Phaedrux Moderator @gorie last edited by
                    @gorie said in Trigger height whitout Z probe:
                    That's a good question, I'm not sure. For a nozzle contact probe the X and Y are 0, but sometimes the Z value is still used. Such as the case if you used a feeler gauge to set the height on the bed, you would have G31 X0 Y0 Z0.2. If you are touching the bed directly, you would have Z0. I would assume that the P value would also be irrelevant, but you could still set it to some value just in case.
