    Issue switching Extruder drives
    • DoxfordCundefined
      DoxfordC
      I need some help figuring out why I can't switch extruder drives.
      I'm running a Duet3D Wifi with version 3 of the firmware.
      For whatever reason, the extruder on my printer recently stopped working. The extruder's stepper is still functional though, so I figured I'd switch from the E0 to E1 extruder driver. As I understand, the way to do this is to change the M563 parameter D0 to D1 in the config file. However, if I do this, all the UI elements for the extruder disappear from the Duet web interface. If I attempt to activate the extruder via g-code, I get a "No tool defined " error. As far as I can tell, the second extruder is fully defined in the config file, shown below:
      M550 PRMAXV32                              ; Printer name
      M555 P2                                    ; Gcode Output Type
      M552 S1                                    ; Enable Wifi
      M575 P1 B57600 S1                          ; PanelDue Comm Setup
      G21                                        ; Work in millimetres
      G90                                        ; Send absolute coordinates
      M569 P0 S0                                 ; Drive 0 goes forwards (X)
      M569 P1 S0                                 ; Drive 1 goes forwards (Y)
      M569 P2 S0                                 ; Drive 2 goes forwards (Z)
      M569 P3 S0                                 ; Drive 3 goes forwards (E0)
      M569 P4 S0                                 ; Drive 4 goes forwards (E1)
      M574 X2 Y2 Z2 S1                           ; set endstop configuration (all endstops at high end, active high)
      M665 R144 L291.06 B135 H400 X0 Y0 Z0       ; delta radius, diagonal rod length, printable radius and homed height
                                                 ; Y X Z are tower angle offsets
      M666 X0 Y0 Z0                              ; endstop offsets in mm
      M350 X16 Y16 Z16 E16:16 I1                 ; Set 16x microstepping w/ Interpolation
      M92 X200 Y200 Z200                         ; Set axis steps/mm
      M92 E178.4:178.4                           ; Set extruder steps/mm
      M906 X1200 Y1200 Z1200 E1200:1200 I50      ; Set motor currents (mA) and idle current %
      M201 X4200 Y4200 Z4200 E5000:5000               ; Accelerations (mm/s^2)
      M203 X18000 Y18000 Z18000 E18000:18000           ; Maximum speeds (mm/min)
      M566 X2000 Y2000 Z2000 E2000:2000               ; Maximum instant speed changes mm/minute
      M106 P0 S0 H-1                             ; Part Cooling Fan
      M106 P1 S0.5 H-1                           ; Case fan
      M106 P2 S1 T50 H1                          ; Heat sink fan
      M307 H0 B0                                 ; Heated Bed (H2)
      M308 S0 Y"thermistor" P"bed_temp" A"Bed temperature" T100000 B4388 R4700 H30 L0         ; Bed thermistor
      M950 H0 C"bed_heat" T0
      M308 S1 Y"thermistor" P"e0_temp" A"Hot end temperature" T100000 B4388 R4700 H30 L0         ; Hot end Thermistor
      M950 H1 C"e0_Heat" T1
      M563 P0 D1 H1                              ; Hot end (T0), drive (E0), heater (H1)
      G10 P0 S0 R0                               ; Hot end operating and standby temperatures
      ;Dual Extrusion Code
      ;M563 P1 D1 H1                              ; Hot end (T1), drive (E1), heater (H1)
      ;G10 P1 S0 R0                               ; Hot end (1) operating and standby temperatures
      M558 P5 C"^zprobe.in" I0 A5 S0.05 R0.4 H20 F2500 ; Strain gauge probe settings
      G31 P100 X0 Y0 Z-0.22                       ; Probe trigger and offset values
      M557 R140 S30                              ; defualt bed mapping
      M501                                       ; Load saved config values
      T0                                         ; Select Tool 0
      M375				; Load height map
      I've also tried D0:1 which yields the same problem.
      Additionally, I've tried uncommenting the the dual extruder section of the config and then manually switching to the second extruder via T1. The first extruder shows up fine, but I can't switch to the second. Checking the tool set-up with M563 P1 gives a "No tool defined" error.
      Any help will be greatly appreciated, thanks.
      • Danalundefined
        Danal
        I believe you need an M584.
        Something like
        M584 X0 Y1 Z2 E4
          dc42 administrators @DoxfordC
          @DoxfordC said in Issue switching Extruder drives:
          That should work, provided you have set up o the current, steps/mm etc. for the second extruder.
          @Danal said in Issue switching Extruder drives:
          Something like
          M584 X0 Y1 Z2 E4
          That's probably the simplest approach.
