    HELP No Connection Possible
    Firmware installation
    • my67nova
      my67nova last edited by
      Just got my duet wifi, duex5, and 7" paneldue, followed instruction to step 10 then NOTHING. Tried all 3 versions of Fallback nothing works SAM-BA never does anything past connect. Is it junk?
      • elmoret
        elmoret last edited by
        1.) Did you press the erase button accidentally?
        2.) What information comes up in the Device Manager for the Port? Could you upload a screenshot of the device manager window?
        3.) Could you also upload a screenshot of SAM-BA, so we can check that you have configured it correctly to flash the firmware?
        The Duet Wifi is not junk, but if it was erased it will need to be reprogrammed.
        A bit of background, OP also mentioned that he has 3 red LEDs lit and 1 green LED, so the board's power supplies are functioning. He's using Repetier Host and said that he can connect to the board but does not get a response.
        • my67nova
          Yes I hit reset disconnecting the USB, in a bad spot. When I said junk I meant broken. http://imgur.com/Hhmmf21
          http://imgur.com/W42tVjb
          • elmoret
            "Bossa Port" is a good thing, that means the board is ready to accept firmware.
            Away from the computer at the moment, but it looks like you have the wrong board selected in SAM-BA. Should be AT91SAM4E8-EK.
