    Duet control no longer shows in the browser
    Duet Web Control
    137
    • drthomasw3
      drthomasw3 last edited by
      I can no longer see Duet control in the browser. The console on the printer says connected. The browser shows connected no errors but blank.
      • A Former User
        which browser/operating system?
        try a private/incognito tab, this will ensure there is no (local) cache issues and may prompt an error.
        • drthomasw3
          No joy on incognito! Tried Chrome, Explorer Page is unsecured but I have allowed permission to access. The same goes for my laptop. I have been using web control fo months and several hours today. Suddenly nothing. I took out the sd card and checked that nothing changed in the network settings of the config.g and reseated the card. The printer is working fine. I am currently printing via the touch screen because of this issue. Hopefully, someone has a suggestion
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @drthomasw3 last edited by
            @drthomasw3 said in Duet control no longer shows in the browser:
            two things; firstly try specifying http:// in addition to hostname / ip (to avoid issues https)
            secondly see if you can open a new tab, hit F12 to open developer console before entering the address, if it fails there will be some clues in either the console or network tab.
            • drthomasw3
              Failed Https the tab had the Duet icon in front of the address but the screen was blank
              With the developer console Message, this sight cannot be reached.
              • A Former User
                you missed the : in http://10.9.65.119/ <- that should eliminate any typos
                then if that still doesn't get you anywhere, it would be the Response part of the headers that would be of most interest.
                • drthomasw3
                  Http://10.9.65.119 changed to 10.9.65.119 after hitting enter. nothing showed up in the console
                  • Danal
                    Danal last edited by Danal
                    No reply; wrong thread.
                    • drthomasw3
                      @bearer said in Duet control no longer shows in the browser:
                      What is the Response part of the headers ?
                      • A Former User
                        The picture you posted only showed what the PC sent the Duet. But as the URL was malformed in that case nothing was returned. If you start fresh with a new incognito tab, open the developer console and type in the url http://10.9.65.119/ it really ought show what we need to know to determine where to look. If nothing is shown then the problem is likely local to the computer somehow.
                        • drthomasw3
                          drthomasw3 last edited by drthomasw3
                          • A Former User
                            Well thats interesting! You're actually getting an empty reply, unexpected..
                            Either somehow the /www/index.htm(l?) file on the SD card is corrupted or something stole your Duets IP address and you're actually connecting to something else?
                            M552 on the console should print your Duet IP just to confirm. Alternatively download fresh DWC files appropriate for your firmware version and try to update the /www folder on the SD card.
                            • drthomasw3
                              DWC files
                              When I start the Duet the screen on the display says: WiFi module is connected to access point
                              "My network with correct IP address"
                                What firmware version are you running on the Duet?
                                • A Former User
                                  A Former User @drthomasw3 last edited by A Former User
                                  It is unlikely to be a problem, but verifying the IP was just the first step, to be 99% sure you're actually talking to the Duet, we'd need to confirm the MAC address as well. It will be part of the M122 output, and running arp -a on the command line on the computer* should allow you confirm they match.
                                  I think I'd confirm the version as dc42 asks for. Output of M115 for RRF firmware version and M122 for the DuetWifi firmware version, then proceed from there.
                                  edit:
                                  *) shortly after trying to access the web interface, otherwise the MAC address will not be in the ARP cache.
                                  • drthomasw3
                                    RepRap firmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                                    Thank you
                                    Tom
                                    • drthomasw3
                                      the M122 gave info about ram but no MAC information. The arp -a command, showed the IP and MAC for the Duet
                                      • drthomasw3
                                        I just ran M540 the MAC addresses do not match Duet looks odd a5:a5:a5:a5:a5:a5
                                        • A Former User
                                          It should be under the Network section of theM122 output, something like (if your terminal line ending is not set to LF it could be truncated)
                                          WiFi firmware version 1.21
                                          WiFi MAC address 60:01:94:nn:nn:nn
                                          drthomasw3 1 Reply Last reply Reply Quote 0
                                          • A Former User
                                            known "bug", for wifi its part of M122.
                                            • drthomasw3
                                              drthomasw3 @Guest last edited by
                                              The display is small there is a bunch of info about ram it is cut off at "Never u"
                                              • A Former User
                                                you're running the command on the PanelDue perhaps? not sure if its possible to make the whole M122 output readable there. Maybe someone else have a suggestion for that. I thought you used the USB/serial console, in which case all you need to do is set the line ending to LF (line feed or unix, no CR or carriage return)
                                                • Danal
                                                  So all of this is to confirm that the IP address the web browser is reaching is really the printer, correct?
                                                  Much simpler way: Power off the printer. The browser should then say that address is unreachable (as opposed to the blank screen).
                                                  • drthomasw3
                                                    I am printing so I can not turn off But yes when off and I type in the IP the message address can not be reached comes up.
                                                    Danal 1 Reply Last reply Reply Quote 0
                                                    • A Former User
                                                      Would still be interested in the wifi firmware version from m122 though
