    The firmware doesn't wait for the temperature to drop
    4.7k
      Yes, M116 with no parameters should work like that. I'll check it out. However, tfree#.g is called just before the tool is deselected, so the M116 command in your tfree#.g files won't do anything because the old tool is still active at that point.
      I normally recommend just M116 P0 in the tpost0.g file and M116 P1 in the tpost1.g file. That way, it waits for the new tool to heat to active temperature, but doesn't wait for the old one to cool down - which takes longer and isn't necessary on most printers. But M116 with no parameters in tpost#.g should work if you want to wait for cool down as well.
      • pcsentinelundefined
        pcsentinel
        So just to verify, if I add
        M116 P1
        M116 P0
        to tpost0
        and
        M116 P0
        M116 P1
        to tpost1
        it should wait for the previous extruder to cool to standby and then wait for the new to heat to active before proceeding?
          Yes, that ought to work.
            pcsentinel
            Hi DC, tested it from the Machine Control, and sorry to say it doesn't appear to be working, i.e. the 2nd extruder starts to heat at the same time as the first extruder is cooling rather than waiting for the first extruder to cool down first, it does appear like there may be a bug in the code here.
              I have just tested M116 on my dual nozzle machine, and it works as expected. However, I did find a peculiarity. If I send a G10 command to change the active and/or standby temperatures of a tool other than the one that is selected, the new temperatures get stored somewhere, but they are not actioned or displayed in DWC. They only get used and shown in DWC when you select that tool. Would this explain the problem you are having?
                pcsentinel
                Hi DC, just retested, cleaned everything out of tool macros apart from
                M116 P1
                M116 P0
                in tpost0
                and
                M116 P0
                M116 P1
                in tpost1
                set active temp to 190 and passive temp to 140 for both.
                wait till tool 0 at 190 and tool 1 at 140
                in console issue a T1 command followed by a G1 X100 Y100, the system doesn't wait it just makes T1 active and moves the bed straight away, rather than my expectation which is that it would wait for T0 to reach 140, T1 to reach 190, then move the bed.
                Also re the oddity with G10, that is also reflected in the web control, i.e. you can select a temp for T1, but it doesn't get applied until you click Tool1 making it active. This also means that the turn all off function doesn't work as expected, so if you set active and standby temps for both tools as above and click Control All, Turn Everything Off, The Bed is turned off, the active tool is turned of but the inactive tool is left at standby.
                  pcsentinel
                  Hi DC, any update on this?
                    Hi pcsentinal,
                    This seems really strange to me. I tested M116 with no parameters and it worked perfectly for me. OTOH the oddity about G10 is reproduced and on my list to look at. Unfortunately it will be a few days before I can look at this again - you can blame the rampant success of the Duet WiFi/Duet Ethernet leading to more support requests and OEM special requirements, and the peculiar tax year end date of 5 April in the UK. So feel free to remind me around the middle of next week. Sorry for the delay! - David
                      pcsentinel
                      Hi DC will do thanks.
                      Really good to here about the success though, fantastic.
                        pcsentinel
                        Hi DC, you asked me to remind you about this.
                          Thanks for the reminder. If I can work out a sensible specification for the change then I'll implement it in firmware 1.19. The specification will be something like:
                          • If you send a G10 Pnnn Rttt command where Pnnn is not the current tool, any heaters that are used by tool ttt and are turned on but not used by the currently-selected tool (if any) will have their live temperatures set to the new standby temperature.
                          It is of course possible that the heaters last had their temperatures set because a different tool was set to standby. So ideally each heater should record the number of the last tool that caused its temperature to be set.
                            pcsentinel
                            That would be expected behaviour, but its also about being able to use M116 so that the print is paused until temps stabilise across the extruders i.e. active extruder gets to active temp and all other extruders get to standby temp then resume print.
                              As I've said before, I have tested M116 without parameters and I can't find anyone wrong with it. AFAIK nobody else has reported a problem with it either. I wonder whether there is something we with the M116 line in your file, or perhaps the file isn't being executed at all.
                                pcsentinel
                                Hi DC, just retested with the following, so may be my interpretation firmware version 1.19 beta 5
                                using macro with
                                T1
                                G1 Y50
                                T0
                                G1 Y150
                                to run test
                                set temps with
                                G10 P0 S190 R140
                                G10 P1 S190 R140
                                from gcode console
                                tpost0
                                M116
                                tpost1
                                M116
                                nothing in any other tool macros
                                Result as expected, i.e. Moves are carried out after each stabilisation of temperature
                                tpre0
                                M116
                                tpre1
                                M116
                                Results in the releasing tool reaching standby temp and not waiting for the new tool to reach temp before the move
                                tfree0
                                M116
                                tfree1
                                M116
                                Results in no waiting i.e. moves are performed immediately with no temperature stabilisation
                                As I said it may be my interpretation, just trying to get my head around the mechanics of the tool macros
                                  The tfree macro is run before the old tool is released, so there will be nothing to wait for. The tpre macro is run after the old tool is released but before the new one is selected. The tpost macro is run after the new tool has been selected. So only the M116 in the tpost file will wait for the new tool to reach its active temperature.
                                  • njjn2020undefined
                                    njjn2020
                                    i have M116 issue too.
                                    in my gcode there is a part
                                    [c]M104 S205
                                    M109 S205
                                    M116
                                    [/c]
                                    but duetwifi does not wait for temperature to raise to 205 and continues to print…
                                    what is a way to command printer to "wait for temperature 205. continue printing when 205 reached" ?
                                      My guess is that you don't have a tool selected at the start. Which firmware version are you running? Later firmware versions will select tool 0 (or your lowest numbered tool) automatically when they see M109 with no tool selected.
                                      • njjn2020undefined
                                        njjn2020
                                        i have
                                        [c]T0 ; select tool 0[/c]
                                        at the gcode file header. firmware is the latest 1.18.1
                                        • c310undefined
                                          c310
                                          should i create tfree0 files?
