Bed Thermistor Fault
Out of the blue I am getting bed thermistor faults due to open circuit. The temperature will read 2000 c intermittently. Nothing has changed on the printer and wiring looks good. Would this indicate that the thermistor itself is bad and needs to be changed?
@psyfor said in Bed Thermistor Fault:
It could be; but another possibility is a bad crimp connection at the connector where it plugs into the Duet.
Ok let me try that first. Thank you.
