    Duet Web Control 2.0.4 - ATX Power Control Missing
    Duet Web Control
    • mitch
      mitch last edited by
      Re: ATX Power button- where did it go?
      I am new to the Duet2 board. I was previously using octoprint with a relay for external PSU control. I have installed my Duet board to use the same relay and all works fine via the M80 and M81 command line control but for the life of me I can't find the option to enable the GUI button in the new 2.0.4 DWC unless I hit the "revert to DWC1" button.
      Once i enter the M80 command the ATX power interface appears. How do I make it persistent?
      infiniteloop 1 Reply Last reply Reply Quote 0
        2.0.7 is out now. See if it's made a return.
        • infiniteloop
          infiniteloop @mitch last edited by
          @mitch said in Duet Web Control 2.0.4 - ATX Power Control Missing:
          As far as I recall, DWC was modified some time ago to only show the ATX power interface if it detects a reference to that functionality in Gcode. So, if you put M81 somewhere in your config.g, the ATX display should return.
          mitch 1 Reply Last reply Reply Quote 1
          • mitch
            mitch @infiniteloop last edited by
            @infiniteloop that did it. Thanks.
            • louvanna
              louvanna last edited by
              M80 in config.g to default ON, and the DWC ATX button,
              or
              M81 in config.g to default OFF and the DWC ATX button.
