Toolchange Macro M116 waits on standby temp, not active.
M116 Pn (for tool number) or Hn (for heater number) does not wait if the selected tool/heater standby temperature is 0. It does not wait on the active temperature.
It does wait on the standby temp, if that is non-zero.
Example tpre0.g
; Runs after freeing the previous tool if the next tool is tool-0. ; Note: tool offsets are not applied at this point! G53 G0 X12 Y320 F10000 ; Rapid to the approach position without any current tool. This lets the human know the next command is waiting on this new tool. M116 P0 ; Wait for set temperatures to be reached
@Danal
In what file do you have this.
I have it in tpost #, the followingM116 P1 S3
What I just remembered are all axes referenced?
All visible axes must be referenced, otherwise the tool change macros will not be executed.greeting
This post is deleted! -
Put M117 (message) commands in all the macros. The all get executed.
M116 P0 never waits on the active temperature. No sequence I could come up with caused it to wait. M116 P0 does wait on the standby temperature for the tool. Very, very, interesting. I also tried M116 Hn. Same thing.
@dc42 is this the intended behavior of M116? The documentation says "... temperatures associated ... " which is ambiguous as to active v standby.
When tpre is run there is no tool selected. So there is no active temperature to wait on. M116 commands should be put in tpost, not in tpre.
@dc42 said in Toolchange Macro M116 waits on standby temp, not active.:
It's kinda counter-intuitive to put wait commands for tool1 in tool0's tpost macro.
@gtj0 said in Toolchange Macro M116 waits on standby temp, not active.:
No, you put them in tool1's post macro.
Thank you, I will do that.
Oh duh. Sorry.
