    BLTouch alarms if triggers & always status of 1000 (I=1 in M558)
    • jrwaters2undefined
      jrwaters2
      I purchased and authentic BLTouch 3.1 from MatterHackers. I read all the documentation I could find and wired it up according to the Duet examples. Specifically:
      Connected the probe to +5, Ground, and Heater 3.
      Other 2 pins are on the Z-probe IN and Ground
      Everything powers up fine - BLTouch self-test completes
      I can control the BLTouch deploy, retract, and self-test.
      There are two oddities here
      1. My Z-probe state is always 1000 whether I deploy or retract
      2. If I deploy and trigger the probe, I get an alarm and BLTouch becomes unresponsive and my Z-state goes to 0, interestingly.
      BTW, If I don't use I1 in my M558 command, I get similar results but Z state is always 0 instead of 1000. Nothing is better. This just gives an indication that inversion is working / matters.
      Here is my config.g. I would appreciate any advice or suggested experiments.
      Thank you!
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Sep 26 2019 16:44:33 GMT-0700 (Pacific Daylight Time)
      M550 P"Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards because Titan Extruder is inverted
      M569 P4 S0 ; physical drive 4 goes backwards because Titan Extruder is inverted
      ;JW there are 2 extruders
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      ;M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation for extruder 2
      M92 X100.00 Y100.00 Z400.00 E418.59:418.59 ; steps per mm for both extruders based on calculations using hobbing distance. Verified with calipers on test cube
      M566 X600.00 Y600.00 Z18.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min) for both extruders
      M203 X7200.00 Y7200.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) for both extruders
      M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00 ; set accelerations (mm/s^2) for both extruders
      ;M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in percent
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in percent for both extruders
      M84 S30 ; Set idle timeout
      M208 X-10 Y-17 Z0 S1 ; set axis minima
      ;M208 X-50 Y-57 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 Y1 Z1 S0 ; set active low endstops. not as safe but this is now Anet A8 endstops wired
      ; JW don't disable Z probe now that I use BLTouch
      ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      ;M557 X20:200 Y20:200 S40 ; define mesh grid
      M307 H0 B0 S0.90 ; disable bang-bang mode for the bed heater and set PWM limit to 90% based on doing M303 H0 S80 P0.9
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M301 H1 S0.69 ; set heater 1 PWM limit to 69% based on experimenting with M303
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      ; JW configuration for second hotend
      M301 H2 S0.69 ; set heater 2 PWM limit to 69% based on experimenting with M303
      M305 P2 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 2
      M143 H2 S275 ; set temperature limit for heater 2 to 275C
      @@ JW My Fan0 Mosfet appears to have gone bad leaving Fan0 always on so I'm using Fan1 pins.
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      ;M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off @@JW Fan test
      ;M563 P0 D0 H1 F0 ; define tool 0
      M563 P0 D0 H1 F1 ; define tool 0 using Fan 1 @@JW Fan test
      G10 P0 X-9 Y0 Z0 ; set tool 0 axis offsets. Chimera+ has perhaps only 18 mm (empirically) between the nozzles so this X offset is -9.
      ; JW second hotend
      M563 P1 D1 H2 F1 ; define tool 1 and make sure it uses second extruder (D1) and second heater (H2). Should not need to specify F0 but using F1
      G10 P1 X9 Y0 Z0 ; set tool 1 axis offsets. Chimera+ has perhaps only 18 mm (empirically) between the nozzles so this X is offset +9.
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      ; JW Enable BLTouch
      M307 H3 A-1 C-1 D-1 ; set heating process parameters for heater 3. A, C, D are dummy variables here
      M558 P9 H5 F100 T2000 I1 ; set Z probe type. 9=BLTouch, H=drive height mm, F=probing speed, T=travel speed to probe points
      ;G31 must come after M558
      G31 X0 Y0 Z0 P25 ; set probe status. X,Y,Z offsets and P=trigger value
      T0 ; select first tool
        For BLTouch you should not use I1. Using i1 may well cause the alarm, because then RRF will detect the probe as triggered immediately. So try again without the i1 parameter. Ensure the probe is well above the bed, home X and Y, then send G30. The probe should deploy and the reading should be zero. Touch the underside of the probe to trigger it. The probe should retract and movement should stop. If movement doesn't stop, cut the power before the probe crashes into the bed.
          jrwaters2
          Hey @dc42 . You are the man. I did try that setting but I was looking for Z values to start at 1000 (retracted) and go to 0 when deployed. From a cursory look, its working! No alarm when I trigger using G30.
          I'm printing out a new mounting bracket and will try it all out - hopefully this week.
          Thank you again!
          Jack
