    Duet WiFi and MacOS - No device found on /dev/tty…
    Firmware installation
    • saffi
      saffi last edited by
      Any idea on what could be causing MacOS 10.12.4 to not find the device?
      Am I missing something simple?
      I also tested it with an older regular Macbook Air and got the same message.
      I pressed the erase button, then waited 5 seconds and pressed the reset button, then waited for 15 seconds.
      When I run the command, it definitely shows up under usbmodem (only port connected) - but it never writes the firmware.
      bash-3.2$ ./bossac –port=/dev/tty.usbmodem1431 -U true -e -w -v -b DuetWiFiFirmware-1.18.1.bin -R
      No device found on /dev/tty.usbmodem1431
      bash-3.2$ ls /dev/tty.
      /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem1431
      bash-3.2$
      Also, it does seem to show up under USB devices:
      Communication Device:
      Product ID: 0x6124
      Vendor ID: 0x03eb (Atmel Corporation)
      Version: 1.10
      Speed: Up to 12 Mb/sec
      Location ID: 0x14300000 / 13
      Current Available (mA): 500
      Current Required (mA): 100
      Extra Operating Current (mA): 0
      Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
      • elmoret
        elmoret last edited by
        Try with root privileges? sudo …
        • leving
          leving last edited by
          I had the same issue after pressing the erase button. Only solution was to flash sam-ba 2.16 by windows.
          • tomasf
            tomasf last edited by
            It's been a while since I last needed to upload firmware manually, but this is what I used then (on macOS):
            [c]bossac -e -w -v -b RepRapFirmware-1.09r-dc42.bin[/c]
            • saffi
              @leving:
              Yeah, I'm about to go find an old Windows 7 box. Sam-ba wasn't cooperating too well with a Windows 10 install so we'll see.
              I'll update once I get it working. I should really run a cheap local Windows 7 computer for non-Mac compatibility.
              • saffi
                Sam-ba 2.16 on a Windows 10 computer actually did the trick. Updated firmware now running!
                  Bossac doesn't he support the SAM4E chip on the Duet WiFi/Ethernet, which is why we tell you to use SAM-BA. We've sent a Duet WiFi to the creator of bossac so that he can add and test support for the SAM4E in it. This should make things easier for Mac users. The newer Duets also have the Erase button set back so that it is harder to press it by mistake.
