    error g0/g1 target position not reachable from current position
    • stweetundefined
      stweet
      I just installed a Duet 2 WiFi on my workbee 750x750
      I use the default workbee firmware and settings.
      But when i try to cut "deep" >5mm i get this error 😕
      What does it mean ?
        Perhaps you're trying to move below what is defined as Z0?
        You may need to allow movement outside set axis limits.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
