    Report motor current with Stall Detection?
    311
    • CJ.BRAVOundefined
      CJ.BRAVO
      was wondering if possible to report a motor current while running a gcode file with use of stall detect?
      Cheers
        dc42 administrators @CJ.BRAVO
        @CJ-BRAVO said in Report motor current with Stall Detection?:
        Cheers
        I'm not sure what you mean. The motor current is the value set in M906 scaled by the percentage set in M913.
        • CJ.BRAVOundefined
          CJ.BRAVO
          @dc42 said in Report motor current with Stall Detection?:
          M913
          I meant the load...
            M122 will report the minimum and maximum load recorded for each driver since M122 was last run (or since power up).
            • CJ.BRAVOundefined
              CJ.BRAVO
              Driver 3: standstill, SG min/max 0/1023
              what is "1023"?
                1023 is the minimum possible load reported by the driver, and 0 is the maximum. 0/1023 is what is reported when the motor hasn't moved yet.
                • CJ.BRAVOundefined
                  CJ.BRAVO
                  Driver 0: standstill, SG min/max 37/201
                  Driver 1: standstill, SG min/max 19/272
                  sorry for the ignorance but what in what units is the measurement? watts? mAmps?
                  piperswundefined 1 Reply Last reply Reply Quote 0
                  • piperswundefined
                    pipersw @CJ.BRAVO
                    @CJ-BRAVO It's a decimal value from a register. You have to take the datasheet in order to do the conversion bits value/ real value.
                      dc42 administrators @pipersw
                      @pipersw said in Report motor current with Stall Detection?:
                      Specifically, section 4 of https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf. M122 reports the minimum and maximum recorded values of the SG register.
