G1 H1 in stop.g cause strange behavior
  • Hi everybody
    I just found that if I put "G1 H1" in my stop.g file I wos't able anymore tu start a new print until i reset printer becouse I receive
    Error: G0/G1: insufficient axes homed
    although I have G28 in the start.g
    my cancel.g is:
    M98 P"stop.g"
    my stop.g is:
    T-1
    M400
    G28 X Y      ;in case there was M84 or M18 in the end of gcode
    G91            ; relative positioning
    G1 H2 Z0.1 F360     ; lift Z by 10mm
    G90            ; absolute positioning
    G1 Y210  F1000 ;
    ;G1 H1 X-200 F1000    ;<-------- This command cause anomaly
    G1 X-10.7 F1000          ;<-------- This command solve my issue
    G1 X5 F6000       ; go back a few mm
    M400
    M140 S0	    ;SET BED TEMP
    M84
    M81 S1      ;aspetta Temp e spegni
    M291 P"DEBUG" T5                ;<---------  never reached with G1 H1  X-200 F1000
    If I try to manually home I got infinite cicle LOOP on button, only way is to reset.
    Whit "G1 H1 X-200 F1000" I never reach "M291 P"DEBUG" T5" on last line of stop.g
    I'm on V 3.0 firmware
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-01-03b3
    My guess is that your slicer start GCode contains a M18 or M84 command to turn off the motors.
  • @dc42
    No, I tryed a custom gcode to test a multimaterial module I'm developing:
    T-1
    G1 U250 F3600
    G1 U0 F3600
    G1 U250 F3600
    G1 U0 F3600
    G1 U250 F3600
    G1 U0 F3600
    G1 U250 F3600
    G1 U0 F3600
    G1 U250 F3600
    G1 U0 F3600
    G1 U250 F3600
    G1 U0 F3600
    just go from 0 to 250, no other instruction and no start gcode from slicer
    and tfreeX.g
    G1 X-10.7 F6000
    M291 P"tfree TOOL X" T3
  • @dc42
    I changed stop .g as follow:
    T-1
    M400
    G28 X Y
    G1 Y210  F1000 ;
    and put
    G1 H1 X-200 F1000
    in console and have no issue to start a new print-file.
    Changed in:
    T-1
    M400
    G28 X Y
    G1 Y210  F1000 ;
    G1 H1 X-200 F1000 ;
    and again no able to start new gcode file.
    Everything I put in the file after
    G1 H1 X-200 F1000
    is not processed, i tried with
    M291 P"HELLO WORLD" T15
    it will newer be displayed
    Firmware version?
  • @dc42 Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3),
    I don't remember if I'm on beta1 or later
  • I think I have solved but I would like a technical explanation:
    an
    M400
    must be placed just before
    G1 H1 X-200 F1000
    @danzaywer said in G1 H1 in stop.g cause strange behavior:
    an
    M400
    G1 H1 X-200 F1000
    The firmware already does the equivalent of M400 before a G1 H1 move anyway. However, I recall a problem in this area in firmware 3.0 that was fixed in the 3.01 beta series. So please can you try 3.01-RC2 and see if that works without that M400 command.
  • @dc42
    Gladly but I got the error "M997 S0 operation has been cancelled"! I uploaded Duet2CombinedFirmware.bin
    from DWC 2.0.7 and answered yes to the update question, what am I missing?
    and M122 give me:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC2 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DGM-917DA-G4MSD-6JKD0-3S46K-KTVZB
    Used output buffers: 3 of 24 (20 max)
    Am I on 3.01 -RC2 or not?
    however in the current situation if I remove the M400 I still have the problem
    Yes, you appear to be running 3.01-RC2. Send M115 to confirm that.
  • @dc42
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC2 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-18b1
    The problem persist.
