    Delta Autocalibration issues
    586
    • DukeMachineundefined
      DukeMachine
      So I've run into an odd problem with autocalibration on my delta printer. It was working fine and I decided to dial it in again since I'd changed the bed surface. Now I try to get it to run the autocalibration and it reaches P3 and kinda of bounces on the spot, then gets to the end of calibration and says it couldn't reach all positions, try a smaller radius. So I try a smaller radius and same problem.
      Any suggestions?
      The error is:
      Error: Auto calibration failed because probe point P3 was unreachable using the current delta parameters. Try a smaller probing radius.
      Bed.g is as follows:
      ; bed.g file for RepRapFirmware, generated by Escher3D calculator
      ; 16 points, 7 factors, probing radius: 40, probe offset (0, 38)
      M98 Pdeployprobe.g
      G30 P0 X0.00 Y20.51 Z-99999 H0
      G30 P1 X14.03 Y16.72 Z-99999 H0
      G30 P2 X26.36 Y4.65 Z-99999 H0
      G30 P3 X34.64 Y-20.00 Z-99999 H0
      G30 P4 X13.68 Y-37.59 Z-99999 H0
      G30 P5 X-13.68 Y-37.59 Z-99999 H0
      G30 P6 X-34.64 Y-20.00 Z-99999 H0
      G30 P7 X-26.36 Y4.65 Z-99999 H0
      G30 P8 X-14.03 Y16.72 Z-99999 H0
      G30 P9 X0.00 Y6.90 Z-99999 H0
      G30 P10 X6.79 Y3.92 Z-99999 H0
      G30 P11 X10.52 Y-6.07 Z-99999 H0
      G30 P12 X0.00 Y-20.00 Z-99999 H0
      G30 P13 X-10.52 Y-6.07 Z-99999 H0
      G30 P14 X-6.79 Y3.92 Z-99999 H0
      G30 P15 X0 Y0 Z-99999 S7
      M98 Pretractprobe.g
        DukeMachine
        Something to add, this problem seems to go away when I delete config-override.g, but reappears as soon as I run M500
        Vetiundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti @DukeMachine
          post your config and overwrite
            DukeMachine
            Config-override is as follows:
            ; config-override.g file generated in response to M500
            ; Delta parameters
            M665 L233.658:233.658:233.658 R123.947 H351.931 B70.0 X0.849 Y0.528 Z0.000
            M666 X1.632 Y-1.108 Z-0.524 A0.00 B0.00
            ; Heater model parameters
            M307 H0 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            Config is:
            ; Configuration file for Duet Maestro (firmware version 3)
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 13:24:52 GMT-0600 (Central Standard Time)
            M550 P"Delta" ; set printer name
            M665 R75 L217 B70 H350 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes forwards
            M569 P1 S0 ; physical drive 1 goes forwards
            M569 P2 S0 ; physical drive 2 goes forwards
            M569 P3 S0 ; physical drive 3 goes backwards
            M350 X256 Y256 Z256 E256 I0 ; configure microstepping without interpolation
            M92 X2560.00 Y2560.00 Z2560.00 E663.00 ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z0 S1 ; set minimum Z
            M574 X2 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
            M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
            M574 Z2 S1 P"!zstop" ; configure active-low endstop for high end on Z via pin zstop
            M558 P9 C"zprobe.in" H30 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
            G31 P500 X0 Y38 Z4.030 ; set Z probe trigger value, offset and trigger height
            M557 R70 S20 ; define mesh grid
            M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
            • Danalundefined
              Danal
              @DukeMachine said in Delta Autocalibration issues:
              config.g
              M665 L217
              config override
              M665 L233.658
              L is the length of your diagonal rods. 217 to 233.6 is a HUGE difference. What are they really? (joint center to joint center)
              • Dougal1957undefined
                Dougal1957
                I would also change the S7 on the last probe point to S6 or S8 so that the rod length doesn't get changed!
                • Vetiundefined
                  Veti
                  this will cause a lot of problems on a delta.
                  please change it to x16 with interpolation
                  your thermistor config is wrong 4138 is wrong
                    DukeMachine
                    Well tried changing to S6 and S8, same issue with both. Tried changing to 1/16th microsteps, didn't seem to work. But I deleted config-override again, ran it with 1/16th, L=217, and S6 and it seems to work. So not exactly sure what the issue was. Some combination of the above I guess.
                    @Veti My thermistor seems to be reading correctly, what should it be?
                    Dougal1957undefined Vetiundefined 2 Replies Last reply Reply Quote 0
                      Dougal1957 @DukeMachine
                      @DukeMachine S7 can cause some strange effects if your starting figures are off as it make a few best guesses (Not exactly but similar) and the firmware calculates a best fit and will adjust the rod lengths which is bad if you know them to be a certain length so S6 or S8 ignores the rod length in the calculations which is why it generally is better to use those factors.
                      • Vetiundefined
                        Veti @DukeMachine
                        what specific thermistor are you using?
                        how do you know that they are displaying the correct temperature? at a temperature of around 200 a wrong setting can easily be off be 20 degrees.
                        • Danalundefined
                          Danal
                          As big a pain as this is... if you have an unknown temp sensor, I would suggest checking it in 0C (ice slurry) and 100C (full rolling boil) water.
