    under voltage
    My Duet controlled machine
    • tdybare69undefined
      tdybare69
      under voltage message
      Resume state saved
      Print auto-paused due to low voltage
      Warning: VIN under-voltage event (9.2V)
      this is what i got after i did a M122
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MS8-6JKDA-3SN6Q-TSV39
      Used output buffers: 1 of 24 (6 max)
      Static ram: 25680
      Dynamic ram: 93780 of which 280 recycled
      Exception stack ram used: 628
      Never used ram: 10704
      Tasks: NETWORK(ready,660) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:08:16 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10792 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 31.4, current 35.6, max 36.6
      Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/307
      Date/time: 2020-02-18 09:02:21
      Cache data hit count 1820081411
      Slowest loop: 3.99ms; fastest: 0.08ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 166, MaxWait: 176ms
      === DDARing ===
      Scheduled moves: 8, completed moves: 8, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.52ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:2d:dc:69
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25752
        WiFi IP address 192.168.0.25
        WiFi signal strength -62dBm, reconnections 0, sleep mode modem
        === Filament sensors ===
        Extruder 0 sensor: ok
        any ideas
      • A Former User?
        A Former User
        check the current draw and actual voltage at the printer terminals? could either be poor connections, thin wires or a wide range of issues.
        if you don't have the means to measure, check what the duet says the voltage is when printer is ide; if it reports the correct voltage at idle, the problem should be with the wirng or the power supply.
        tdybare69undefined 1 Reply Last reply Reply Quote 0
          tdybare69 @A Former User
          @bearer thank you
            Or you might have had a power brownout, like I did yesterday.
