    How to remove new Duet Web Control 2.0 and revert to 1.2x?
    Duet Web Control
    301
    • Neotkoundefined
      Neotko
      Hi, I know that there's a button to 'revert' that just sends to the 1.22 reprap.html
      How can I 'truly' revert to 1.22, it's an added time to go from 2.x to click 1.22 and get back to production.
      I suppose editing the sd card html and remove the index with the reprap.html ? Just asking to be sure I don't screw stuff 😄
      • jens55undefined
        jens55
        The old interface is located at IP#/reprap.htm.
        Depending on how you get to the web interface, you can also use that method (name for example) and follow it with "/reprap.htm" (without the quotes)
        • A Former User?
          A Former User @Neotko
          @Neotko said in How to remove new Duet Web Control 2.0 and revert to 1.2x?:
          Supposedly yes, and if you do " helical inclined plane" stuff you vann always just rename and restore the index file.
          Caveat, I'm not sure what the comparability is for 1.22 these days.
          Neotkoundefined 1 Reply Last reply Reply Quote 1
          • Neotkoundefined
            Neotko @A Former User
            @bearer
            I just tried that without any effect... I will have to push this. I just prefer the base ip to have the control I use on all the other machines. I see a lot of work done, but it has too many screens goes and outs, old version just works fine for me and I know there’s a customizable something out there but much work and no time to play makes me prefer just what works
            • A Former User?
              @bearer
              It could be cashed. Try a incognito tab?
              • Neotkoundefined
                @bearer
                Indeed cleaned all caches since that was my first thought, also tested incognito to be sure like you suggested.
                Don’t know, I did replace the index, both gz index files htm and html and still shows the new 2.0 I will have to dig later to see from where is loading the 2.x
                • A Former User?
                  The web server has a fixed list of files to look for, and in that order. So removing index.* ought make it move on.
                  Try renaming reprap to index? Although I was under the impression there was a setting to revert, possibly by means of a cookie, if that doesn't work it might be deprecated all together?
                  • Neotkoundefined
                    @bearer
                    Ok now, replaced the index with the gz un compressed, replaced the htm and html index gz with the reprap gz. Everything back to 1.22
                    Thanks for the guidance!
