Step 9 - Check Access to Duet Web Control not working
  • • When I send the IP address assigned to the Duet, I get
    Hmmm…can’t reach this page
    • When I ping the address I get
    Pinging xx.x.xx.x with 32 bytes of data: Request timed out.
    • When I try to access the Duet by typing "http://duettest.local/" I get
    Site can’t be reachedduettest.local’s server IP address could not be found.
    • This is a brand new Duet 2 Wifi board bought from Filastruder
    • I called my internet provider “Spectrum” and traced the IP address and to our amassment the address I was typing in was being routed as a different address, Hmmm….
    • Need someone with technical experance on this board for HELP
  • @cdalyai said in Step 9 - Check Access to Duet Web Control not working:
    what does that even mean?
    which address does the duet have? is it static or dhcp?
    same for the computer?
  • You will need to tell us more about the network to which you are attempting to connect the printer.
    What is the address of your PC?
    What is the address of your Router?
    P.S. Internet service providers generally do not provide very good support for the network inside your home. They support from your router (and/or modem) to their network to the internet. Take with a huge grain of salt anything they say about the network on "your" side of the router/modem.
    What IP address has been assigned to the Duet, as reported by the M552 command?
  • @bearer What does that even mean?
    Let me try to explain the best I can… The firmware is pointing to IP address 10.1.50.4 and the Duet board is pointing to 10.2.107.215
    I don’t know for sure if it’s a dynamic IP address via DHCP or a static address… I’m pretty sure it’s DHCP which is the default for most setups. By the way the setup did not give me an opportunity to select one or the other.
    My computer is on a Private Net- Work and the IP assignment is set to Automatic (DHCP)
  • @Danal What is the address of your PC?
    I’m not sure I want to give that information in this forum, but it is set to Automatic (DHCP)
    I do not have a personal Router. Please read description below. I do know it is an Intel® Dual Band Wireless-AC 3165
    A little information about my setup:
    1- I’m connected into a commercial community setup with the internet provider “Spectrum Community Solutions”.
    2- I have no control of any of the equipment ( Modem/Router etc. ) They own it…
    3- I have to sign in to Spectrum Community Solutions WiFi from my computer any time I add a new device then add the device to a list of authorized devices. And then and only then connect the device to my WiFi network.
    4- There is a local Spectrum office twenty minutes from my home, but they are not authorized to work on or do any trouble shooting on this setup. I have to work directly with Spectrum Community Solutions WiFi.
  • @dc42 What IP address has been assigned to the Duet, as reported by the M552 command?
    10.1.50.4
    these are on different networks most likely. which in itself shouldn't be a problem but given they're both local networks the routing would need to be configured correctly. being a community type network it could also be they have enabled client isolation.
    lets start by running route print on the computer and posting the output, as well as M554on the duet.
    edit: can you also just confirm both computer and duet are connected to wifi, and the same ssid, and if possible determine if there are multiple bssid's for the same ssid?
    IP addresses are "neutral" or "harmless" from a security point of view.
    Thank you, that is extremely helpful.
    When you "Sign in to Spectrum Community Solutions WiFi from my computer..." is that via a web page? I'm going to assume so for a moment and state that the Printer can't do this... can't sign in. As such, I doubt that the printer will ever be able to join the Spectrum Community Solutions WiFi network.
    Therefore, the printer will need to operate in "Acccess Point" mode. This is documented here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
    The exact sequence is to connect to the printer via USB and enter:
    • M552 S0
    • M589 S"ssid" P"password" I192.168.9.2
    • M552 S2
    DO NOT use your existing SSID! Make up a new one. DO NOT reuse the first three parts of your existing IP address structure. For you, do not use 10.1.x.x or 10.2.x.x on the M589 command. The address I gave above for the M589 "I" (eye) parameter should work.
    Then use a computer, phone, or tablet to connect to the SSID you picked above, and in a browser open HTTP://192.168.9.2
    Once you get connected, ensure that M552 S2 is somewhere in your config.g This will bring up the AP at each boot. Do not put the M589 in config.g, only the M552 S2
  • Unless its a google translate type thing, he did say to sign in from the computer to register the new device; as such the new device shouldn't have to deal with a captive portal or registration?
    10.1.50.4
    what do you mean the Duet board is pointing to 10.2.107.215? the M552 command is authoriative in this case; the firmware, which runs on the Duet board has the IP address 10.1.50.4 if that is what M552 says.
  • @bearer said in Step 9 - Check Access to Duet Web Control not working:
    Maybe. It could be read either way.
    Please find .JPG attached for the route print...
    The M554 command returned the following...
    serial:554
    Gateway 192.168.1.255
    Wifi: ip 0.0.0.0, mask: 255.255.255.0, gw:10.1.50.
    Also here is M587
    17:33:25.867 : TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
    17:33:25.867 : BV_East3rd_713 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    Thanks for your help....
  • @Danal
    I will attempt working on your suggestion tomorrow.
    Tonight is a full schedule.....
  • Mkay route print confirms the Duet and the computer are on two separate networks 10.1.50.0/24 for the Duet and 10.2.107.0/24 for the computer. Weather or not its possible to communicate between the two is up to the provider.
    You can try tracert 10.1.50.107 if that is still the address for the Duet, but its only a so and so test.
    The main focus should be why is the Duet on a different network.
    Also here is M587
    Is the computer connected to one of these? Remove the one that the computer isn't using.
    You can try setting up an Access Point like Danal suggest but if you're using the wifi for your Internet connection you will not be able to access the Internet while accessing the printer (you can switch back and forth ofcourse); but I would try to find out how to get them on the same network (or to make life easy I'd buy a wireless router that could connect to the community wifi and provide a private wifi to you where you don't have to fiddle with their administration at all).
    It could be the printer has a weaker antenna and not able to connect to the same network as the computer? So confirming which network the computer is connected to is the next step imo.
    Agreed.
    "Ten dot", by default, would be inclusive of every possible address after the 10. However, with a subnet mask of /24, the game changes. (The /24 also shows up in the routing table as 255.255.255.0). This forces all three leftmost octets to be part of the subnet, and only the last octet be station.
    Phrased another way: 10.x.y.z/24, each station that has identical values for x and y can talk (assuming they are on the same media) directly with each other. Any pair of stations who's x or y is different, must go through a gateway (IP terminology for a router) to talk.
    So... I'm not clear on how the Printer would ever get a 10.1.n.n address when the PC received a 10.2.n.n address from DHCP... but... they can not talk directly to each other, and, as @bearer said, they may or may not be able to talk through the router, depending on the Provider setup.
    Therefore... with all the unknowns here... I'd still recommend giving a shot to AP mode, as detailed several posts above.
    And... in the "grand scheme of things", I would ABSOLUTELY do this, even if I had to invite network savvy friends over to get it done!
  • @Danal
    GOOD NEWS!> It's up and running....
    Spectrum had to manually add the Duet in their master device list even though I added it into my personal device list
    Bad News> Spectrum cannot give me a static address or they don't want to.
    So I'm thinking if I shut down the Duet it may not connect again because the IP will change. What do I do from this point on???
  • Getting your own router will solve any problem with addresses, but I'd wait and see if it is a problem before deciding. Presumably you'll be in your own subnet or you should consider the security implications of that and get a router.
    In any case you can see if mdns works for you. http://duet.local or if your have changed the name change the url accordingly
  • @bearer
    http://duet.local will not work
    Spectrum will not turn on manual or give me a static address. They are telling me the solution would be 1- leave the printer on continually 2- Get my own service and router so I would have complete control.
    I do not want to go that way at all.
    Does Duet have a stand-alone card that is not WiFi, that I can use on my Tevo Delta Printer?
    will not work? or does not work? i believed it was supported again in the recent firmware versions, but it does require client support as well.
    Stand alone card? They have the wifi and the ethernet version; and they have the PanelDue to control the printer without any network at all.
    (You could always use the Duet as the Access point as hinted to above with the mentioned limitations as well)
    "Get your own router" does not absolutely require "get your own service".
    Yes, it is called Duet Ethernet. However... this still attaches to SOMETHING; in your situation, a very good choice might potentially be an ethernet card directly in your PC (and a CAT5 wire between the two). That would avoid completely avoid Spectrum.
  • @Danal
    To make sure I’m on the same rabbit trail as you, would the following be correct.
    If I exchange the current Duet2 Wi-Fi board for a Duet2 Ethernet board and connect it to my computer I could print directly from the computer via Duet Web Control?
    Or would I be printing from my computer via printer firmware (Repetier-Host/Simpilify3D etc.) ?
    And by the way thanks for your help and being there for hobbyist like me.
    yes. you'd need to set up static ipaddresses for both the duet and the computers wired ethernet interface and connect either a direct cable or a switch inbetween. (if the computers wired network doesn't support auto mdi/mdx you'll need a crossover cable (for the direct connection)).
    if you avoid setting a gateway for the wired interface I believe you should be able to use both the wired and wireless networks at the same time to access both the internett and the printer.
  • @bearer
    Ok, Thanks again for your help.
    consider this case closed...
