    DUET3 + PI: DWC "hang" or sluggish? /etc/fstab?
    Beta Firmware
    257
    • Danalundefined
      Danal
      I added an automount CIFS filesystem to /etc/fstab (to enable backups of the entire Pi SD). If the automount failed and was retrying in the background, this would cause long delay in random DWC responses, and cause a very consistent delay in the restart after an "Emergency Stop"
      Commenting that out of /etc/fstab and rebooting (I know... I know...) made everything snappy again.
      So, I will put it back in without automount, and mount it when I need it for backups.
      • gtj0undefined
        gtj0
        When you mount it manually and it succeeds is the DWC (actually the Duet Web Server) still slow or only if it fails and is retrying?
        Danalundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal @gtj0
          @gtj0 said in DUET3 + PI: DWC "hang" or sluggish? /etc/fstab?:
          Haven't tried that yet. Will report here when I do.
          • gtj0undefined
            gtj0
            Yeah. The web server may be trying to do something dumb like scan the filesystems when a request is made. It may not even be in @chrishamm's code. It may be in Microsoft's.
            • Danalundefined
              Danal
              OK, been doing some additional testing. I can detect no slowness with the file system in /etc/fstab and 'noauto'. I can detect no slowness when I intentionally break security so that it doesn't mount. I can detect no slowness when it mounts.
              The only circumstance where I clearly see delays is when 'auto' is set in /etc/fstab, yet the mount fails and periodically retries in the background.
              There may be other effects; some of this stuff is a little hard to pin down.
              • gtj0undefined
                gtj0
                Try combinations of the following mount options...
                • soft
                • x-systemd.mount-timeout=500ms
                • x-systemd.device-timeout=500ms
                Experiment with the times to see if you can arrive at a value that works.
                • Danalundefined
                  Danal @gtj0
                  • soft
                  To be clear, many different ways to both have this mount and no delays. The only clear failure at this point is 'auto' (the default) with
                  //USDNLW11/RPiBackups /RPiBackups cifs user=pi,password=xxxxx,x-systemd.automount 0 0
                  And the Windows machine was refusing the connection.
                  Note this is not that great an fstab entry... among other thigns, it really should have '_netdev'.
                  But, again, back to delays: Only the fstab entry above, which fails over and over because windows was refusing it, causes the perceptible delays in DWC.
                  • gtj0undefined
                    gtj0
                    Yeah I was trying to see if setting a shorter timeout wouldn't hang things. I can try more stuff tomorrow. My printer is in pieces today.
                    • Danalundefined
                      Danal
                      At this point, I actually cannot reproduce the failure. I'll keep trying, and if I do, I will try the timeouts.
