    Heater fault in 3.01
    heater 3.01 fault nozzle
    • Fritz Weundefined
      Fritz We
      That is what I get for my E3D after I updated to fw 3.01. I tried for hours to solve this. But with no success...
      I managed to get the heated bed running. But not the hotend.
      This is the heaters config out of the config tool:
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0 Q5 ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S85 ; set temperature limit for heater 0 to 85C
      M307 H0 A486.1 C2320.7 D16.5 S1.00 V24.0 B0 ; PID-parameters for heated bed
      M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
      M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S265 ; set temperature limit for heater 1 to 265C
      Any suggestions? Somebody?
        dc42 administrators @Fritz We
        What response do you get if you send the whole M308 H1 command from the console?
        I suspect that you may need to use the cs0 or cs1 pin in that command instead of cs2.
        Fritz Weundefined 1 Reply Last reply Reply Quote 0
        • Fritz Weundefined
          Fritz We @dc42
          M308 H1 S1
          Sensor 1 type PT100 (MAX31865) using pin spi.cs2, reading 2000.0, last error: sensor short to other wiring, 2/4 wires, reject 50Hz, reference resistor 400 ohms
          Not sure, but it looks like the spi.cs2 is correct?
            @Fritz-We said in Heater fault in 3.01:
            Please try disconnecting the PT100 cable where it connects to the daughter board, and connect the 100 ohm reference resistor in its place. That should give a reading close to 0C.
            EDIT: you have configured a PT100, but the comment says it is a thermocouple. Which is it?
            • Fritz Weundefined
              Fritz We @dc42
              It is actually a PT100 (orig new E3D Titan Aero). Connested directly to the e0thermistor input on the Duet 2 Maestro. The the thermocouple came from the config tool. If I select E3D there, then it sets the thermocouple. But doesn't matter. Even if I put in all parameters manually - it fails in the same way.
              I connect the hotend thermistor to the bed thermistor input - the hotend temp was shown.
              DocTruckerundefined 1 Reply Last reply Reply Quote 0
              • DocTruckerundefined
                DocTrucker @Fritz We
                @Fritz-We didn't think PT100 aren't supported direct ro the board, only via daughter board.
                https://duet3d.com/Duet2Maestro
