    M116 appears to be not working
    362
    • appjawsundefined
      appjaws
      This is my shutdown macro but the M116 is not working so the macro completes still with the hot end hot.
      I am using the latest firmware 3.01-RC2
      M291 P"Shutdown Started" R"Shutdown" S1 T0; Display message
      echo "Extruder temperature = " ^ heat.heaters[1].current
      if heat.heaters[1].current > 35
      M98 P"0:/macros/Set LED Green"
      echo "LED Green on "
      M291 P"Waiting for nozzle to cool" R"Shutdown"; Display message
      M106 P1 S255 ;set cooling fan to maximum
      M104 S35 ;reduce extruder heater to safe level
      ;G10 P0 S35 ; reduce extruder heater to safe level
      M116 :wait for set temperature
      echo "Extruder temperature should be 35 = " ^ heat.heaters[1].current
      G4 P2000
      echo "G4 Dwell set to 2000 milliseconds "
      M104 S0 ;reduce extruder heater to zero
      ;G10 P0 S0 ;reduce extruder heater to zero
      M106 P1 S0 ;set cooling fan to zero
      echo "Extruder heater set to 0 "
      M291 P"Shutdown Completed" R"Shutdown"; Display message
      M0
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        If you set a heater to 40C or below then M116 doesn't wait for it, because it might never get there.
        If you really want to wait for 35C then you could use conditional GCode:
        M104 S0
        while heat.heaters[1].current > 35
          G4 S1
        • appjawsundefined
          appjaws
          thanks, that worked great
          Simplify3D 5.1.2
          • appjawsundefined
            appjaws
            On more testing I noticed that as soon as M106 P3 is called the fans[3].actualValue is 1.0
            So the LED is at max brightness and stays there.
            If I run the macro a second time it works. I tried to put M106 P3 S0 to start but that didn't work either.
            this is the log
            Run2
            LED Red Requested value = 0.60
            LED Red Actual value = 0.6
            24/02/2020, 12:10:42
            LED Red Requested value = 0.50
            LED Red Actual value = 0.5
            24/02/2020, 12:10:40
            LED Red Requested value = 0.40
            LED Red Actual value = 0.4
            24/02/2020, 12:10:39
            LED Red Requested value = 0.30
            LED Red Actual value = 0.3
            LED Red Requested value = 0.20
            LED Red Actual value = 0.2
            24/02/2020, 12:10:37
            M98 P"0:/macros/Set LED Red"
            Initial LED Red Actual value = 0.1
            Run1
            24/02/2020, 12:10:24
            Initial LED Red Actual value = 1.0
            This is the macro
            M106 P3 S0
            echo "Initial LED Red Actual value = " ^ fans[3].actualValue
            while fans[3].actualValue < 0.6
            M106 P3 S{fans[3].actualValue + 0.1}
            G4 S1 ;Wait for 1 second
            echo "LED Red Requested value = " ^ fans[3].requestedValue
            echo "LED Red Actual value = " ^ fans[3].actualValue
            Simplify3D 5.1.2
              Try testing requestedValue instead of actualValue. The actualValue may take a short while to catch up with requestedValue.
              • appjawsundefined
                appjaws
                Thanks,
                That worked so that I only needed 1 run, but it still started with a value of 1 (Full Brightness)
                24/02/2020, 14:07:24
                24/02/2020, 14:07:22
                24/02/2020, 14:07:21
                24/02/2020, 14:07:20
                24/02/2020, 14:07:19
                24/02/2020, 14:07:18
                LED Red Requested value = 0.00
                24/02/2020, 14:07:17
                Simplify3D 5.1.2
                  If you don't run that macro, is the fan/LED output off or on to start with?
                  • appjawsundefined
                    appjaws
                    @dc42 The fan/LED output is OFF to start but as soon as I run the macro the LED is very bright and then drops to the first increment 0.10.
                    Its almost as if the output blips to full power from idle, perhaps to aid actual fans to start quicker.
                    25/02/2020, 10:59:04 Red LED Requested value = 0.10 Red LED Actual value = 0.1
                    25/02/2020, 10:59:03 M98 P"0:/macros/Set LED Red" Initial LED Red Actual value = 0.0
                    Simplify3D 5.1.2
                      dc42 administrators @appjaws
                      @appjaws said in M116 appears to be not working:
                      It's exactly that. See the M106 B parameter.
