    Increasing M106 S value in a macro incrementaly
    • appjawsundefined
      appjaws
      I am trying to change the brightness of my LED strip slowly to a preset value.
      Using M106 P3 and increase the S value in increments.
      This is the macro
      while fans[3].actualValue < 40
      M106 P3 S^fans[3].actualValue + 2
      ; {Sfan[3].requestedValue} = {Sfan[3].actualValue} + 2
      G4 S5 ;Wait for 5 second
      echo "LED Red Requested value = " ^ fans[3].requestedValue
      echo "LED Red Actual value = " ^ fans[3].actualValue
      Error M106: expected string expression
      Is this possible?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        @appjaws said in Increasing M106 S value in a macro incrementaly:
        Try:
        M106 P3 S{fans[3].actualValue + 2}
        In any standard GCode command (not meta command like 'if' or 'while'), if you want to use an expression as a parameter value, you must enclose the expression in { }.
        • appjawsundefined
          appjaws
          @dc42 said in Increasing M106 S value in a macro incrementaly:
          Thanks, great answer, I am learning a lot.
          Simplify3D 5.1.2
