    RRF3.01-RC2 CoreXY - Tool Definition and multi commands ?
    Firmware installation
    368
    • Dr_Ju_Juundefined
      Dr_Ju_Ju
      Getting closer to a fully working system, thanks to DC, but I've come to a couple of 'funnies'...
      M122.csv config.g
      Firstly, while trying to define a tool, as per the wiki, I'm unable to add multiple drives, heaters or fans etc to a single default tool definition. The additional 'object' always result in "No Tool defined"
      I've not found any additional posts\info on this, so is it me, missing other config settings (M140's ? I have tried to no avail) or does not work as per the wiki anymore ?
      The second relates to running multiple G\M commands on a single line, e.g. in the DWC console window, if I enter G28 space G29, the G28 command is executed, but the G29 isn't executed, but the console window, reports successful completion.
      Julian,
      Old goat, learning new things….
      Danalundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • Danalundefined
        Danal @Dr_Ju_Ju
        @Dr_Ju_Ju said in RRF3.01-RC2 CoreXY - Tool Definition and multi commands ?:
        The Duet G-Code document says:
        Multiple commands on a single line
        RepRapFirmware allows multiple G- and M-commands to be included in a single line. Each occurrence of G or M on the line that is preceded by a space or tab character and is not inside a quoted string or a command starts a new command.
        Also, it works for me, with the test "G28 Y G28 X". Each is executed, in sequence.
        Board: Duet 3 MB6HC (MB6HC)
        DSF Version: 1.2.4.0
        Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
        • Dr_Ju_Juundefined
          Dr_Ju_Ju
          For me, when I try that same command (G28 X G28 Y or G28 Y G28X) the initial G28 is executed, but the second command is not.
          Julian,
          Danalundefined 1 Reply Last reply Reply Quote 0
          • deckingmanundefined
            deckingman @Dr_Ju_Ju
            I guess you mean this line in from your config.g
            "; M563 P0 S"Extruder" D0:1:2:3 H0:1 F0:1 ; define tool 0 - No Tool Defined"
            Regarding the drives, you only have one extruder drive defined - "M584 X0 Y1 Z2 E3" So in your M563 D0 is the first extruder which you have connected to E3. Drives 1,2, and 3 would be the next extruders in the order that you define them in M584.
            Regarding the heaters, H0 is the bed heater so you probably can't assign that to the hot end. If you have multiple hot end heaters, you need to define them somewhere and use H2, 3 etc.
            Regarding the fans, you've defined fan0 as the part cooling fan but fan1 as a thermostatic hot end fan so you can't use that as part cooling fan. If you have multiple part cooling fans, you need to define them as non thermostatic and use fan2, 3 etc.
            • Danalundefined
              Danal @Dr_Ju_Ju
              What is your board/release/etc? You can find this on the "machine specific" tab in the web interface.
              • Dr_Ju_Juundefined
                Dr_Ju_Ju
                Thanks Ian, so as I suspected, unless I define additional 'objects' they can't be added to the tool.
                Danal, I've included the output from M122 above i.e.
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC2 running on Duet Ethernet 1.02 or later
                Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
                Julian
                Julian,
                • Danalundefined
                  Danal
                  I'm on 3.0, you are on 3.01-RC2.
                  I just upgraded to 3.01-RC2
                  Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-RC2 (2020-02-18b1)
                  And "G28 Y G28 X" still works fine.
                  • Danalundefined
                    Danal
                    On the "General" tab, what Duet Web Control are you running?
                    Duet Web Control 2.0.7
                    • Dr_Ju_Juundefined
                      Dr_Ju_Ju
                      yes DWC 2.0.7
                      Julian,
