    How to remap tool heater connection from E0 to E1
    1.1k
    • edjrwinntundefined
      edjrwinnt
      I just finishing a HEVO build and my heater has been inconsistent the few times I've tried to heat my hotend as I was building this printer. Now that I have the printer completed it no longer heats at all. What do I need to change in my config.g file to use the E1 heater port as the tool 0 heater source?
        Are you running RepRapFirmware 2 or 3? Send M115 to check, and post your config.g file
          edjrwinnt
          I got it figured out and the E0 heater port on the board works. I did not know how to turn on the extruder. This is like learning a new foreign language. It's all new to me after doing several other printer builds with Marlin and Klipper. It seems kind of weird though that the bed comes on when I turn the temperature up but the hot end does not. It could be a little more user-friendly in my opinion.
            dc42 administrators @edjrwinnt
            @edjrwinnt said in How to remap tool heater connection from E0 to E1:
            Most other firmwares don't really understand tools, only heaters. We try to make allowances for new users in RRF, like selecting a tool automatically if M109 is received with no tool selected; but we can't make too many assumptions because RRF is used in a very wide range of machine configurations.
              edjrwinnt
              @dc42 said in How to remap tool heater connection from E0 to E1:
              M109
              Okay now I am getting a heater error a minute or two into the print and my wiring is fine, plus I have a newer thermistor and heater cartridge. How do I remap the heater to use the second hotend heater connection on my Duet Maestro board instead of the first? I did a PID autotune too. I changed the thermistor type from what it was from B4138 to B4725 for my Semitec 104GT2 thermistor.
                That doesn't necessarily indicate a hardware problem. Have you read https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them ?
                  edjrwinnt
                  I am using the latest 2.0x firmware from February. I will adjust the heater timeout to see if that will work. What is it by default and where is that in the config files? I see that the M570 S120 gcode command will set it too. I do not have a strong fan and I get a heater error with the fan off.
                  If you could let me know how to remap the heater connection hotend 0 to hotend 1, I would appreciate it too. I was not able to find that doing a simple google search. I've done it before in Marlin.
                    Look for your M563 command in config.g and change H1 to H2 in that command. You will also need a M305 H2 command in config.g similar to the M305 H1 command that is already there. Move the hot end thermistor to the E1 thermistor connector too.
                      edjrwinnt
                      These are the two lines that I changed in config.g and I'm getting an error, Temperature reading fault on heater 2: sensor open circuit, with my Heater 2 temp showing 2000.0 degrees 😄
                      M305 P2 T100000 B4725 R2200
                      M563 P0 D0 H2 F0
                      I move the thermistor connector to the thermistor 2 connection on the board.
                        edjrwinnt
                        This is what I have now under heaters:
                        M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
                        M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
                        M305 P2 T100000 B4725 R2200 ; set thermistor + ADC parameters for heater 1
                        M143 H2 S280 ; set temperature limit for heater 1 to 280C
                          Please confirm which Duet you are using. If it's a Maestro then it has 4 thermistor connectors in total, so please make sure you have selected the right one.
                            edjrwinnt
                            I tried the one right next to the one that was working for E0 and the third one that is close, diagonally from E0 that worked. I have a Maestro.
                              It's the one labelled E1 Temp, next to E0 temp that you were using before. the third one in that area is labelled C Temp.
                              You can use the E0 Temp connector instead if you add parameter X1 to your M305 P2 command.
                              BTW that M305 P2 command is probably wrong because the B4725 parameter is normally used with a C parameter too, to model the hot end thermistors shipped by E3D.
                                edjrwinnt
                                After connecting the thermistor to E0 again, I added X1 to M305 P2 and it now has a reading of room temperature. However when I go to heat it up it will not heat and I get the heating too slowly error. I did change B4725 to B4138 like I had before.
                                  edjrwinnt
                                  Here is my whole config.sys file now with the changes to use the E0 thermistor port and the hotend connected to the second heater, E1:
                                  ; Configuration file for Duet Maestro (firmware version 2.03)
                                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 23 2020 13:06:27 GMT-0500 (Eastern Standard Time)
                                  M550 P"HEVO" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  M918 P1 E4 F2000000 ; configure direct-connect display
                                  M552 P192.168.11.111 S1 ; enable network and set IP address
                                  M553 P255.255.255.0 ; set netmask
                                  M554 P192.168.11.111 ; set gateway
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S1 ; physical drive 0 goes backwards
                                  M569 P2 S1 ; physical drive 2 goes backwards
                                  M569 P3 S1 ; physical drive 3 goes backwards
                                  M92 X80.00 Y80.00 Z400.00 E843.00 ; set steps per mm
                                  M566 X600.00 Y600.00 Z300.00 E600.00 ; set maximum instantaneous speed changes (mm/min), was 720 for x & y
                                  M203 X9000.00 Y9000.00 Z1800.00 E1800.00 ; set maximum speeds (mm/min)
                                  M201 X1800.00 Y1800.00 Z100.00 E9000.00 ; set accelerations (mm/s^2), was 2500 for x & y
                                  M906 X950 Y950 Z800 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X300 Y300 Z375 S0 ; set axis maxima
                                  M574 X1 Y1 S1 ; set active high endstops
                                  M574 Z1 S2 ; set endstops controlled by probe
                                  M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                  M557 X15:215 Y15:195 S20 ; define mesh grid
                                  M305 P2 T100000 B4725 R2200 X0 ; set thermistor + ADC parameters for heater 1
                                  M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M563 P0 D0 H2 F0 ; define tool 0
                                  M501 ; added by ed jr 3/7/2020
                                    Are you saying that it's not heating up at all? Does the red LED next to the E1 Heat output light up when you select tool 0 and command it to heat up?
                                    Given that you couldn't make it work on E0 output either, it sounds to me that either the heater cartridge or the wiring is faulty.
                                      edjrwinnt
                                      I'm on my second heater cartridge. The first one was a new 24V one from E3D and the second one is a Trianglelab one. There is not much print time on either and the first one from E3d went bad.
                                      I noticed that the wire connectors on my thermistor plug to the board was loose. I pressed the connectors in tight but I did not rewire the plug like I should have. I will do that later. It started working again but now it won't go over 211 degrees celsius. I have my print set for 225 and it is stuck at 210 or 211 and it has not timed out with an error surprisingly. I did not change the heater timeout either. It finally did give an heater fault error after a few minutes of not getting up to temp.
                                      I did not check the led but I will the next time. I would like to get the heater remapped to E1 port on the board if possible to eliminate that the E0 port is bad. I don't understand why I had one cartridge go bad and then another if the second cartridge is bad.
                                        edjrwinnt
                                        It seems to have a problem at higher temps but only while printing. I just cranked it up to 235 and it held firm there while the printer was idle for a few minutes. Maybe the vibrations are affecting my weak thermistor connection to the board.
                                          edjrwinnt
                                          I found the problem. It is because of my fan being on! I only have a single fan on the hotend, and the hotend has a sock on it! I turn the fan off and the temp shoots right up. I know that I should have known better but on my 7 other, home built, printers I never had this problem, especially when using a single fan for cooling and a heat block sock. The only difference with this machine is that it's 24 volt, including the cooling fan, versus 12 volt on the other printers that I built.
                                            Did you run your PID tune with the fan on? That can help.
                                            edjrwinntundefined 1 Reply Last reply Reply Quote 0
