    Why 0.7 Z offset in a probe?
    626
    • Danalundefined
      Danal
      If I define a probe with M558, and then execute G31 (with no arguments), I see:
      G31
      Current reading 0, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
      Why is the trigger height 0.7?
      I realize I can G31 K0 X0 Y0 Z0... but if I do that, and then undefine the probe and redefine it (which I'm doing to zero a toolchanger in different ways), it is back to 0.7. Again, I realize that undefining the probe 'uncouples' it from the G31, or the G31 'goes away' when the probe is undefined... I'm not asking why that happens... I am asking why 0.7 is wired in there somewhere.
      Why 0.7? Why not 0.0?
      This was very surprising to me, and took a really long time (months) to track down, simply because I couldn't imagine that a newly defined 'thing' in RepRap would have a fixed bias.
      spllgundefined 1 Reply Last reply Reply Quote 1
      • spllgundefined
        spllg @Danal
        @Danal i feel that defining g31 z0.25 in config.g has no effect. after a power cycle reboot g31 reports z =0.7. i'll check the effect of g31 z0.25 in config-override.g later today.
        Danalundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal @spllg
          @spllg said in Why 0.7 Z offset in a probe?:
          At this moment, I have added a G31 K0 X0 Y0 Z0 in my config.g, and that does work across reboots, etc. Also, I dynamically re-define probes and endpoints in a script that is designed to calculate tool-to-tool alignment... and that script has been updated to issue G31 commands every time it redefines Z probes.
          Anyway, G31 in config.g is working for me.
          spllgundefined 1 Reply Last reply Reply Quote 0
          • spllgundefined
            spllg @Danal
            @Danal Duet 3 6HC (v0.6) - RepRapFirmware 3.01-RC2 with RPi 4B - dwc 2.0.7-1?
            • Danalundefined
              Danal
              Board: Duet 3 MB6HC (MB6HC)
              DSF Version: 1.2.4.0
              Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-RC2 (2020-02-18b1)
              Duet Web Control 2.0.7
              • Danalundefined
                Danal
                And, just checked, same thing on:
                Board: Duet WiFi 1.02 or later
                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
                Duet WiFi Server Version: 1.23
                • spllgundefined
                  spllg @Danal
                  @Danal double checked: g31 z0.35 in config.g is ignored and g31 70.25 is honored when in config-overrige.g.
                  curretnly i'm unable to do any further tests/checks because of https://forum.duet3d.com/topic/14614/unable-to-home-xyz-using-my-homing-scripts
                  • Danalundefined
                    Danal
                    So after that nice discussion about G31...
                    Does anyone (hint: @DC42) know why probes have 0.7 Z offset, unless you override it?
                    • Danalundefined
                      Danal
                      OK, the physical, literal, reason is this line of code in module "RepRapFirmware/src/Platform.h"
                      // Z PROBE
                      constexpr float Z_PROBE_STOP_HEIGHT = 0.7;						// Millimetres
                      But that begs the question: Why?
                      P.S. That module's header says:
                      Version 0.3
                      28 August 2013
                      Adrian Bowyer
                      RepRap Professional Ltd
                      http://reprappro.com
                      So maybe I should be asking Adrian.
                        droftarts administrators @Danal
                        @Danal said in Why 0.7 Z offset in a probe?:
                        // Z PROBE
                        Version 0.3
                        28 August 2013
                        Adrian Bowyer
                        It might be the value that was correct for the very first printer to use Duet, the RepRapPro Ormerod 1, which had an unmodulated IR sensor. I can't quite remember. But even that seems rather low.
                        • themelleundefined
                          themelle
                          Got an answer from Adrian - for the curious ones 😉
