    Is G Code file the same for delta and carthesian designs?
    Example setups and prints
    • NEVER LUCKYundefined
      NEVER LUCKY
      hi, im trying to print something on my custom designed delta printer, but im not sure i am doing it right. im using a duet 2 maestro.
      so my plan is:
      1.upload the stl file in cura
      2.create a gcode file with creality cr10s settings (not running on a duet board)
      3.upload the file i created to the DWC and start printing on my delta printer.
      i have already created a height map and calibrated the extruder and everything seems to be working just fine thanks to all who helped.
      is it alright if i use the cr10s settings and all in cura to make the gcode file? or is there a way to add my custom printer to cura and create the file then? or does it even make a difference or not?
      or should i use something other than cura to create the file?
      thanks!
      • SIamundefined
        SIam
        @NEVER-LUCKY said in Is G Code file the same for delta and carthesian designs?:
        creality cr10s
        Short answer this will not work because you are using two diffrent Printer. You must make a extra Profile for your delta Printer.
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • Danalundefined
          Danal
          Yes and no.
          The biggest typical incompatibility is that Cartesian printers almost always have X0Y0 in a corner. Delta printers almost always have X0Y0 in the center of the bed. So a print sliced for cartesian will print way off on one 'side' of the Delta, often pushing it out of the boundary of the print bed.
          The best answer, as mentioned above, is to create a new printer profile in Cura. This should take less than one minute.
            https://ultimaker.com/en/resources/52029-manage-printers
            See adding a custom printer.
            You may be able to use the CR-10 print settings profile to some degree, but you'll need to tell Cura you're using a delta so it knows the shape of the bed.
            • Danalundefined
              Danal
              Example Delta:
                NEVER LUCKY
                @Danal said in Is G Code file the same for delta and carthesian designs?:
                incompatibility
                alright, ill get to it then, thanks again!!
