    help for mesh grid
    • PuddingBaer91undefined
      PuddingBaer91
      Hi there,
      i tried a lot but got it not working. The head always move too long or too short or i get an error (no valid mesh grid).
      This is my setup:
      Could you please help me? Thank you
        droftarts administrators @PuddingBaer91
        @PuddingBaer91 Is X0 Y0 (bottom left corner) where the X and Y endstops are triggered? So the nozzle is -25mm off the bed in X, and -15 off the bed in Y? And the nozzle can't reach the last 15mm of bed in Y? If so, your M208 commands should be:
        M208 X-25 Y-15 Z0 S1                             ; set axis minima
        M208 X330 Y315 Z350 S0                             ; set axis maxima
        This would limit the nozzle to being within the bed area. With your probe offsets, X-35 Y20, the probe can reach X0, but only 330+10-35=X305. For Y, it can reach from -15+20=Y5 to the nozzle maximum, at 330-15+20=Y335. This would be off the bed, so can just limit that to 330. Then take all of these, and add a 5mm safety margin to get:
        M557 X5:300 Y10:325        ;  probe points 5mm within axis limits
