Current limit on 5V Pins on Duet3 26 pin connector?
Are the traces such that a single 5V pin on the 26 pin connector can safely power the Duet3 or are both needed? I'm pretty sure only one is needed but just wanted to check.
I've seen current ratings varying from 1 to 3A for the "dupont" style connector, so it would depend more on the female terminal than the male pin and conductor between them than the trace (if memory serves me there is just the one trace connecting both pins so the the PCB doesn't care if you use one or two pins)
Heh. I didn't think to look at the schematic. Yeah the pins are bridged so it doesn't matter.
