    Custom Shapeoko
    Duet Web Control
    • vimes1984undefined
      vimes1984
      I've purchased a shapeoko mechanical kit and a wifi duet controller from ooznest.
      I've loaded the firmware from ooznest, and instaled the limit switches and all "homes" well, but I'm struggeling to get it to "go to work XYZ" I get the following error:
      M98 P"workzero.g"
      Error: G0/G1: target position outside machine limits
      I'm not sure what to do 🙂
      this is my config.g file
      ; Configuration file for Duet
      ; WorkBee Firmware Version 1.0.7
      ; Configure Connection - ENABLE ONLY ONE OF THE BELOW THREE
      M552 S1 ; Enable Wifi Network
      ;M552 S2 ; Enable Access Point Mode
      ;M552 S1 P192.168.2.14 ; Enable Ethernet - Change IP Address to suit
      ; DO NOT CHANGE ANY OF SETTINGS BELOW
      ; TO MAKE A CHANGE, COPY THE LINE OF CODE, PASTE IT INTO customconfig.g. THE CHANGE CAN THEN BE MADE IN customconfig.g
      ; ANY ADDITIONAL SETTINGS SHOULD BE PUT IN customconfig.g
      M453 ; Put the machine into CNC Modes
      M550 PWorkBee CNC Machine ; Set machine name
      G90 ; Set absolute coordinates
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Configure Drives
      M584 X0 Y1:3 Z2 ; Apply drive mapping to axes
      ; Configure Axes
      M92 X53.334 Y53.334 Z400 ; Set steps per mm
      M350 X16 Y16 Z16 I1 ; Configure microstepping
      M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes (mm/min)
      M203 X10000 Y10000 Z2500 ; Set maximum speeds (mm/min)
      M201 X150 Y150 Z150 ; Set accelerations (mm/s^2)
      M906 X2400 Y2400 Z2400 I100 ; Set motor currents (mA)
      ; Configure Axis Limits
      M208 X800 Y1270 Z94 S0 ; Set axis maxima
      ; Configure Endstops
      M574 X2 Y2 Z2 S0 ; Set active low endstops
      ; Other Settings
      M140 H-1 ; Disable heated bed
      M564 S1 H1 ; Disable jog commands when not homed
      M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
      M501 ; Load Stored Parameters
      M98 Pcustomconfig.g ; Execute custom config settings
      this is my customconfig.g
      ; ADD ANY CUSTOM SETTINGS BELOW
      M550 P "Mega robot" ;
      ; Configure Drives
      ; Configure Axes
      M574 X2 Y2 Z2 S1 ; Set active low endstops
      ; Other Settings
      M564 S1 H0 ; Disable jog commands when not homed
      and this is
      workzero.g
      ; workzero.g
      ; called GO TO WORK ZERO is pressed in WorkBee Control
      G1 H1 Z1500 F1500 ; raise the Z to the highest position
      G1 X0 Y0 F1500 ; go directly above the work zero position
      G1 Z0 F1500 ; go to the work Z zero position
      someone please help, I'm a Javascript dev not a gcode dev yet 🙂
      • A Former User?
        A Former User @vimes1984
        @vimes1984 said in Custom Shapeoko:
        would suggest you're trying to do a move that is larger than the defined dimmensions for the machinem, which are set by
        so
        is outside of that, but i waa lead to believe the H1 parameter would take care of that for a homing move.
        on a side note you have this inside customconfig.g which calls itself?
          vimes1984
          Hey bearer!
          thanks for the answer, so how would go about increasing the dimensions for the machine?
          SO the "Home XYZ" works fine it's the "SET WORK XYZ" that gives me the error or if I try to lower the z so the spindle touches the work peice..
          • A Former User?
            A Former User
            Huh, I was wondering if that could be the case, but as far as I know there wasn't any limitations preventing G1 H1 to work outside of homeall.g.
            In any case if the dimensions are wrong you change them in the lines that say M208 and set axis minima/maxima.
            I would for simplicity remove all duplicate lines from customconfig.g (if its in config.g its a already set, so unless you want to override it its redundant).
              vimes1984
              Here's what I ended up doinanyone is curious and needs to set up a workbee updgrade kit on a custom machine 🙂
              I edited the following files:
              homex.g
              homey.g
              homez.g
              homeall.g
              and the custom config file with the size of my machine...
