Gcode upload failes
  • I printed something last night and wanted to start a new print this morning.
    But I am unable to upload the Gcode.
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L4MSN-6J9F2-3S86P-T902N
    Used output buffers: 3 of 24 (9 max)
    Static ram: 30516
    Dynamic ram: 91836 of which 0 recycled
    Exception stack ram used: 224
    Never used ram: 8496
    Tasks: NETWORK(ready,728) HEAT(blocked,1240) MAIN(running,3676) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:02:30 ago, cause: software
    Last software reset at 2020-03-01 07:58, reason: User, spinning module GCodes, available RAM 8208 bytes (slot 2)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 6.7ms, max retries 0
    MCU temperature: min 36.9, current 37.5, max 37.9
    Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-03-01 08:01:43
    Cache data hit count 410603317
    Slowest loop: 7.43ms; fastest: 0.09ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 16.33ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    WiFi firmware version 1.23
    WiFi MAC address 84:0d:8e:b3:b0:3a
    WiFi Vcc 3.39, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 24288
    WiFi IP address 192.168.178.47
    WiFi signal strength -69dBm, reconnections 0, sleep mode modem
    Socket states: 0 2 0 0 0 0 0 0
    What happens when you try to upload the GCode file?
  • it first shows 26%, sometimes it directly goes to error and the other times it moves really slowly up and that moment it would go to 100% it shows error.
    Tried to upload 8 times and the ninth it uploaded successfully.
  • After the first success I didn't had another error.
    @X30N said in Gcode upload failes:
    Your WiFi signal strength is a little low. If you experience further errors, see https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors.
