    G-Code or Config for max or preferred hotend heatsink cooling speed?
    • saffiundefined
      saffi
      I put a 40mm fan on my E3D which may be overkill, but it's quite loud at a max of 255. Can this be set to 150 in the config somehow so when the hotend reaches 50C (or the trigger temperature), it turns the fan on S150?
      Thanks
      Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
        Yes you can do that. Add the S parameter to the M106 command that defines the thermostatic fan parameters.
        • saffiundefined
          saffi
          Of course, I should've thought of that. Thank you.
