    Microstepping with "dumb" external stepper driver?
    • jlmoreno
      jlmoreno last edited by jlmoreno
      How would microstepping be set with a "dumb" external pololu or stepstick type driver?
      Is it still done with M350, or do I need to use the MS1,MS2,MS3 inputs on the driver pcb?
      what happpens if, for example, the driver is set up for x16 microstepping on the board, but x64 with M350?
      • A Former User
        You'll need to set them both, and matching; if you set x64 microseteps in M350 an x16 on the driver it will move 4mm for every 1mm you want it to move.
        Ofc RRF is smarter than that; ref dc42 👇
          dc42 administrators @jlmoreno last edited by
          @jlmoreno said in Microstepping with "dumb" external stepper driver?:
          The Duet doesn't know what microstepping your external driver uses. So just set the external driver to the microstepping you want, then in config.g set the steps/mm in M92 to be correct for that microstepping.
          • A Former User
            @dc42 so is it only if you change the microstepping after setting steps/mm you can run into interesting situations with such a setup?
              dc42 administrators @Guest last edited by
              @bearer said in Microstepping with "dumb" external stepper driver?:
              I think you will find that RRF doesn't let you change the microstepping on a dumb driver.
              • jlmoreno
                Awesome, i'll give it a shot. Thanks!
