    Overextrusion issue with the hemera
    • maroonds
      maroonds last edited by
      I'm getting massive overextrusion with my hemera extruder and I'm not sure why.
      I calibrated my extruder by printing a single wall cube over and over till I reached the perimeter line width that I set in prusa slicer. My current extruder settings are:
      16x microstepping
      395 steps per mm
      Extrusion multiplier set to 0.94%
      Here are some pics: imgur.com/a/D2PsCYc
      This was printed with the same filament which I used to calibrate my extruder. (Prusament lipstick red)
      • DocTrucker
        DocTrucker last edited by DocTrucker
        My process for calibrating rigid materials...
        • Calibrate e-steps so that 100mm (+/-0.5mm) is delivered when requested when there is no hotend after the extruder. Do not reverse and repeat along the same piece of filament.
        • Check extrusion into free space for 7 speed points ranging from a filament speed of 0.5mm/sec to just over the maximum volumetric limit of the hotend. Eg 10mm3/sec with 3D V6 and PLA. Repeat tests with speed and extrusion distance scaled in order to stablish correction values for linear / non linear extrusion.
        • Set extrusion multiplier to 1.
        • Do a vase mode print on a 25 x 25 x 10mm cuboid with 3mm rads on the corners. Adjust filament diameter (using volumetric extrusion) until wall thickness is accurate. (using digital micrometer)
        • print solid coupons 20 x 20 x 3mm with decreasing extrusion multiplier until there is gaps between the extrusion lines, then back it up a little.
        • Do pressure advance calibration.
        • Check and minimise retraction value.
        Edit: Above assumes you are happy with current extrusion temp setpoint! With the exception of e-steps calibration chamging temp result in a need to start from the beginning for the above.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
          There's also this method.
          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
          Your part looks ok in those pictures. Where is the massive over extrusion?
