    Problems with Configuration Tool
    Firmware installation
    • Barracuda72
      Barracuda72 last edited by Barracuda72
      I had a defective SD card and unfortunately due to a PC change no backup. So I had to reset my Delta Printer and changed to the new firmware. I used the Config Tool. DuetWifi and SW 3.0. The two PT1000 sensors show wrong ( what worked fine under the 2.x. Homing does not work anymore ( goes to the endstops and instead of shutting down, it stops at the switched endstops. It is not possible to create a reasonable config.g with this tool. Z-Endstop is grayed out and cannot be selected. The parameters for the sizes don't fit either ( e.g. printable area maximum 105mm and that where I have a 300mm print bed). The config is hardly suitable as a first clue.
      0:/sys/config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 08 2020 13:43:36 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"My Printer" ; set printer name
      M665 R175 L386 B145 H380 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X160.00 Y160.00 Z160.00 E450.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      ;M574 Z1 S1 P"null" ; configure active-high endstop for low end on Z via pin null
      M574 Z1 S1 P"zstop"
      M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      My Printer
      Send code...
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      0.0
      Y
      0.0
      Z
      380.00
      Extruder Drives
      Drive 0
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.3 V
      MCU Temperature
      30.1 C
      Z-Probe
      0
      Tools
      Extra
      Control All
      Tool Heater Current Active Standby
      Tool 0
      T0 - Load Filament Heater 1
      off 168.9 C
      0
      0
      Bed Heater 0
      off 169.4 C
      0
      0
      Temperature Chart
      System Directory
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 08 2020 13:45:33 GMT+0100 (Mitteleuropäische Normalzeit)
      G91 ; relative positioning
      G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
      G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-15 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      Then i wanted to switch back to a 2.x version..but that dont work..updated it and its still the 3.0 version..
      any hints for me?
      just tried again..downloaded the latest version..uploaded it to the printer...started the update and got this
      M997 S0
      Error: In-application programming binary "Duet2CombinedIAP.bin" not found
      • Barracuda72
        that really drives me crazy..used the config tool over and over again...finally i got the 2 PT1000 back to work...even had one Calibration via G32..put the new numbers into my M665 and M666 but now my Homing dont work...he runs into endstops...lower 10mm and makes a 2nd run..goes up into endstops and stops there..the dont lower again...
        ; homedelta.g
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 08 2020 17:21:54 GMT+0100 (Mitteleuropäische Normalzeit)
        G1 H1 X380 Y380 Z380 F1800 ; move all towers to the high end stopping at the endstops (first pass)
        G1 H2 X-10 Y-10 Z-10 F1800 ; go down a few mm
        G1 H1 X20 Y20 Z20 F360 ; move all towers up once more (second pass)
        G1 Z-30 F6000 ; move down a few mm so that the nozzle can be centred
        with that homedelta it worked before but not anymore...and because homing dont work i get this error message
        G28
        Error: G0/G1: target position not reachable from current position
        same with g32
        G32
          Can you check that version 3 firmware was actually applied? Send M115 to check version.
          Duet2CombinedIAP.bin is in the same release as the 3.0 firmware. You need that file present on the SD card to be able to roll back to the previous 2.x firmware.
          Unfortunately, I'm not sure about your delta homing problem.
          • Barracuda72
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
            strange..schouldnt it be something with RC3? it was the last version..anyway...the homing prob is very odd...because if it occours i have to turn off the printer and sometimes it works after that cold reset
            • Barracuda72
              ok..solved the Homing Problem...checked it several times that i choosed the active high endstops but in config.g they were active low...
              Holy sh?* my first config after i bought the duet wifi was so easy compared to bring my Delta back to live now
