    Conditional Gcode: Test if key exists?
    • mwolter
      mwolter last edited by
      I am attempting to make a filament load macro that detects the movement of a Duet magnetic filament monitor. Running into an issue as the "calibrated" key does not exist in the object model until a print is started.
      It does not exist before print starts...
      M409 K"sensors.filamentMonitors[0]"
      {"key":"sensors.filamentMonitors[0]","flags":"","result":{"configured":{"mmPerRev":25.80,"percentMax":150,"percentMin":50,"sampleDistance":6.0},"enabled":true,"type":"rotatingMagnet"}}
      But after it does...
      {"key":"sensors.filamentMonitors[0]","flags":"","result":{"calibrated":{"mmPerRev":27.17,"percentMax":106,"percentMin":85,"totalDistance":577.4},"configured":{"mmPerRev":25.80,"percentMax":150,"percentMin":50,"sampleDistance":6.0},"enabled":true,"type":"rotatingMagnet"}}
      Before the print starts the key returns null...
      M409 K"sensors.filamentMonitors[0].calibrated"
      {"key":"sensors.filamentMonitors[0].calibrated","flags":"","result":null}
      But if I make a macro to test for null...
      if sensors.filamentMonitors[0].calibrated = null
      	echo true
      else
      	echo false
      This is returned to the console...
      M98 P"0:/macros/test"
      Error: in file macro line 1 column 49: M98: cannot convert operands to same type
      Should I not be comparing to null? Is there a different type?
        Which firmware version are you running? My latest build gives this:
        10/03/2020, 18:46:58 	echo sensors.filamentMonitors[0].calibrated = null
        true
        mwolter 1 Reply Last reply Reply Quote 0
        • mwolter
          mwolter @dc42 last edited by mwolter
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC3 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-29b4
            dc42 administrators @mwolter last edited by
            If that same echo command doesn't work for you, then I guess it's fixed in the internal build ready for 3.01-RC4.
            • mwolter
              Confirmed does not work on RC3. Will postpone this project until RC4.
              3/10/2020, 2:08:10 PM	echo sensors.filamentMonitors[0].calibrated = null
              Error: cannot convert operands to same type
                You can try the internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 if you wish - at your own risk.
                • mwolter
                  @mwolter said in Conditional Gcode: Test if key exists?:
                  That works, thanks!
